Results 1 to 3 of 3
Thread: clutch movement 818S
    I have a 818S which utilized a 2006 WRX donor. My clutch pedal has always had extremely small movement between engagement and non. Any suggestions to give me more space in the pedal movement since it is very difficult in traffic to avoid stalling the car. Regards; Capt. Bill
    Senior Member AZPete's Avatar
    Check that the arm of the clutch slave cylinder is seated in the middle of the indention in the release lever. That caused me a similar symptom.
    Adjust the threaded arm between the clutch pedal and the clutch master cylinder.
    Hi Pete: Thanks for the clutch input; I will try what you suggest. Any chance there is air in the line? Capt. Bill
