Results 1 to 5 of 5
Thread: For Sale MK IV # 8483 Colorado Springs, CO
    Thanks for all the interest - It sold yesterday (8/14/2017)
    For Sale FFR MK IV Roadster # 8483 located in Colorado Springs, CO
    The build is in the go-kart stage with full running chassis. It requires minor finishing sheet metal and body work. I started this build in 2014, in Nebraska and subsequently married and moved to Colorado. I am just not able to finish it. Below is a listing of options and upgrades. The engine and rear center section were built by Mike Fortes, Fortes Parts Connection. The engine and transmission were professionally installed and tuned as well as four wheel alignment. I have pictures and video for serious inquiries as well as a contact with a Classic Automobile Restoration Shop in Omaha that can comment on the quality of the build.
    Over $45,000 invested - asking $28,500 OBO. Email - [email protected]
    MK IV COMPLETE KIT (FFR, INC, www.factoryfive.com)
    Powder Coat Chassis
    302 Headers
    Body Cut-outs
    Vinyl Roadster Seats
    IRS Components
    Electric Vintage Gauge Upgrade
    17” Halibrand Replica Wheels
    Stainless Side Exhaust
    Wind Wings
    Sun Visors
    Windshield Wiper Kit
    Brake Duct Wire Mesh
    11.65” IRS Brakes
    Roadster Heater/Defroster
    Stainless Steel Bumper Kit
    MK IV Logo Floormats
    ENGINE (Fortes Parts Connection)
    Dart Block 363 Cubic Inch (Dyno @ 443 HP @5750 RPM / 450 ft/lbs @ 4300 RPM
    Cobra Valve Covers and Air Cleaner
    SCAT Forged 3.4” Stroke Crankshaft
    SCAT 5.4” “H” Beam Rods
    Mahle 4.125” Forged Dished Piston
    Edelbrock 60255 Heads
    Edelbrock 7121 Performance RPM Intake Manifold
    Ford Racing E-303 Camshaft & Roller Lifters
    Canton 15-630 9 QT Front Sump Oil Pan
    Holley 550-405 Terminator EFI
    Aeromotive Fuel Pressure Regulator
    MSD 302 TFI Distributor
    M-12259-R301 9MM Red Wire Set
    Autolite 3923 Spark Plug
    KRC SBF Power Steering Pulley, Pump and Reservoir
    DRIVE TRAIN
    Tremec TKO-600 (TCET 4617) 5 spd Transmission
    Bellhousing Kit
    Mustang 5.0 Fork
    Ford Performance Clutch Linkage Upgrade
    Ram 88794T Clutch Kit
    26/31 Spline Driveshaft
    Cobra IRS Rear End Center Section 3.55 (Fortes Parts Connection)
    MISCELLANEOUS
    Russ Thompson Turn Signal
    Weatherpak Electrical Connections
    Breeze Power Steering Rack
    Breeze Front Battery Mount
    Breeze Radiator Fan Shroud Mount
    Breeze Lower Radiator Support Kit
    CNC Dual Master Cylinder Reservoirs
    Wilwood Remote Brake Balance Bar Adjuster
    Nitto 245/45/R17 Tires
    Nitto 315/35/R17 Tires
    6AN Teflon Lined Braided Stainless High Pressure Fuel & Power Steering
    Master Disconnect Switch
    FF Metal 0.090 Aluminum Firewall
    John Phillips
    [email protected]
    Member Race Ratz's Avatar
    Harwich, MA
    This car won't last long. Good deal!
    Have you considered hiring Mark Dougherty, The Traveling Builder, because I'm sure he could get you out of the ditch and back on the road?
    My recommendation is to not give up on your dream unless you are 100% sure that selling your car won't bug you in the end, meaning the rest of your life. My chassis is number 8,515 and I had some life issues too like my oldest daughter got married, youngest daughter graduated college, tried to chop my fingers off, one of which had to be reinstalled, son graduated from high school and now just went off to college.
    My point is I'm where you are and am still plugging away so don't give up now, things are just about to get really fun.
    https://youtu.be/BcsVu80VG5k
    Never Give Up, Never Surrender!
    https://youtu.be/SJ2hJezvd2I
    Mark Dougherty's Avatar
    Hershey PA
    put me in coach
    The traveling Builder
    717-773-5624
    Quote Originally Posted by Mark Dougherty View Post
    put me in coach
    Mark, wouldn't you rather be in First Class ...
