OK, I wanted to start another message here just to point out three things that I had to do but were not in the manual. I guess I need to ask if it will do any good... Will anyone ever update the manual?
Anyhow, here is what I have found so far. From what I understand there will be many more along the way.
#1. When installing the power steering motor the manual says to use the three bolts and that it will look like this.
In my case there was a cover and a bushing that was put onto the motor and then the bolts went though it and into the motor. I think it looks much better with the cover and so far it is not in the way of anything.
#2 When installing the cap on the master cylinder it does not tell you to put the O-Ring in the groove before putting on the cap.
#3 When installing the break light switch it shows it like this...
but my switch looks very different.
