Results 1 to 18 of 18
Thread: Speedo Calibration
    Senior Member bill3422's Avatar
    Wasington, DC area
    Speedo Calibration
    When calibrating the speedometer, once in calibration mode and traveling the 2 mile run, is there a speed that needs to be maintained?
    Bill3422
    MK4 - 302/347 Stroker - AFR Heads - 400 Hp
    no
    Jun 2015
    Fairfax Station VA
    To amplify on what Mike said, the speedometer is counting pulses from the speedo sensor in the transmission. You don't have to maintain any set speed, and you can speed up or slow down as you desire / the road dictates.
    P.S. Bill, you're quite the lurker. Only 104 posts in 6 1/2 years? Wow!
    MK IV Roadster #8631
    Wasington, DC area
    104? Wow, that many? Thank you for the information.
    Bill3422
    Like others have said, you can go any speed you want.
    The first time I calibrated my speedometer, I went "about" 2 miles. That was not good enough. I checked my speed with a GPS unit and it was off by about 10 mph at highway speeds. I recalibrated and went exactly 2 miles. Now I am pretty accurate. Hope that helps. Good luck.
    Calgary, Canada
    I haven't done mine yet, but I would like to understand how it can calibrate knowing the number of pulses.
    Quote Originally Posted by chopthebass View Post
    Because you go a prescribed distance. Number of pulses / distance = speed calibration value it stores.
    Depends on the speedo..
    The Classic Instruments speedo calibration was done by maintaining a set speed. I used a hand held GPS to give me a speed read out, then adjusted the black box until the speedo read the same. We then tested it at several speeds, and checked the odometer against hwy mile markers, and it was dead on.
    Are people still using the VSS from the trans even with the GPS gauges? If so, what is the reasoning; more accurate?
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Quote Originally Posted by AC Bill View Post
    I assumed the question was about the Speedhut gauges, since they seem to be the most common. Autometers also calibrate in a similar manner. But you're right. Classic Instrument gauges do require you to drive a fixed speed. My Mk3 build had those. That was a while ago, but looking at their current instructions appears it's still the same.
    The VSS can't be used with GPS gauges. No wires to hook one up plus no internal mechanism to use the signal. The gauge is one or the other. I have the GPS gauge in my #8674 Roadster. Based on what I can tell, it's dead on accurate.
    That is true. In spite of all the issues people have had with the Speedhut, they still seem the most popular. I presume that's because, that's what comes in the Complete Kit.
    You'd think FFR would offer the Classic Instruments, and perhaps the Smith gauges, as optional choices, but perhaps there's not enough profit in it for them.
    On a roll Al_C's Avatar
    Wheaton, IL
    OK, maybe I'm hijacking the thread (for which I apologize), but it is related... check out the photo. The connector for the speedometer at the transmission has two white wires. The wires from the gauge connector (classic) is one white, one black. Or in the RF bundle, one white, one gray. I have to believe that it does matter which way you connect it. But which way? Thank you for not getting annoyed at this slight diversion.
    My roadster wasn't wired with the RF harness, but I was led to understand it makes no difference, as long as one of the leads from the VSS is grounded. My Classic speedo works fine.
    Since I have the GPS speedo, what should I do with the harness and opening in the driver's side trans tunnel wall? I suspect I could eliminate the harness, but not sure if it's better to keep it and just wrap it up.
    I'll just silicone a patch over the hole unless it is needed for something else.
    Legal: 1/30/2020
    Senior Member weendoggy's Avatar
    Aptos, CA
    I'd just tape the end and leave the connector in tact. You never know..... Also, just cut a small piece of aluminum (if the kit didn't come with the plate) and place it over the hole with silicone and rivets. I'd put the rivets in from the transmission side because you have insulation/carpet that will not show the rivet plug. Later on you know why when you're under there doing work and catch your hand on the rivets if you put them in from the cockpit side.
    I'm just a victim of a thousand physic wars!
    www.weendoggy.com/cobra.htm
    Quote Originally Posted by weendoggy View Post
    Perfect!
    Legal: 1/30/2020
    Your kit came with a patch for that location. Looks like an oval with one end cut so it had a straight area.
    Thank you. I'll track that down.
    Legal: 1/30/2020
