Thread: Need some advice after compression check
    Jul 2017
    The Villages Fl.
    My donor is a 2004 WRX with 164K miles. It had a new short block installed at 60k. Compression test shows all cylinders at 125psi. cold. It also has about 15lbs vacuum when warm. I don't intend on racing the car, but may have some limited track time. I want to keep the cost down and do not intend on putting more than a few thousand miles per year on the car. So I want reliability and basically stock motor, or warmed slightly if cost effective. I am thinking basically rings, bearings, timing belt, water pump, oil pump, valve job.
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    That's low on compression. I'd do a new Subaru shortblock and have the heads done.
    If the heads were not done with the last short block replacement I would almost assume thats the cause of the lower compression. Otherwise you would think a short block with 100k miles wouldn't be that bad already
    Jul 2017
    The Villages Fl.
    Thanks Wayne, your comments are much appreciated.
    Jul 2017
    The Villages Fl.
    Thanks for your feedback. I will know more when I get it apart, hopefully, just some headwork.
    Feb 2013
    Westminster, MD
    Compression tests should be done on a warm/hot engine. Cold numbers are not a useful measure.
    Get engine to temp, fans on, fans off.
    All plugs out.
    WOT.
    Crank 10-15 times.
    the numbers being grouped together is more important than the numbers themselves. on a cold engine i'd say those numbers are fine. keep in mind these are low compression engines and the final numbers have a lot of variables at play, like engine temp, condition of compression tool, crank time etc.
