I have my gauges wired and the dash zip tied in place and now I have to decide where to mount the turn signal switch, hi/lo beam switch, and hazard switch. I'm thinking the hazard and hi/low beam switches will get mounted in a dash brace near the left edge of the dash. The turn signal switch should go in the dash, but I'm not sure how the padded dash will handle drilling additional holes. I don't want to shred the padding around the hole with a drill bit. Any tips?
I assume the switch on the left is the turn signal (3-way), and the one in the middle is for the hi/lo beam, but I'm not sure about the switch on the right with the six pins. I assume it's the hazard flasher switch?
Finally, any help with where to connect the wires would be great. There are two sets of turn signal wires (a single left and right and a pair of three-wire bundles for left and right). Which ones go to which switch? The high/lo beam wires are simple, and I assume a ground goes to the center pin on the switch.
