Results 1 to 24 of 24
Thread: Electrical Switch Questions
    I have my gauges wired and the dash zip tied in place and now I have to decide where to mount the turn signal switch, hi/lo beam switch, and hazard switch. I'm thinking the hazard and hi/low beam switches will get mounted in a dash brace near the left edge of the dash. The turn signal switch should go in the dash, but I'm not sure how the padded dash will handle drilling additional holes. I don't want to shred the padding around the hole with a drill bit. Any tips?
    I assume the switch on the left is the turn signal (3-way), and the one in the middle is for the hi/lo beam, but I'm not sure about the switch on the right with the six pins. I assume it's the hazard flasher switch?
    Finally, any help with where to connect the wires would be great. There are two sets of turn signal wires (a single left and right and a pair of three-wire bundles for left and right). Which ones go to which switch? The high/lo beam wires are simple, and I assume a ground goes to the center pin on the switch.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Lost Wages, Nevada
    NOOOOOOO . . . NO grounds at the Hi/Lo switch. Center pin is for the feed to the switch (inbound) from your headlight switch, other two pins are Hi and Lo (outbound).
    FWIW, most switches we use in our cars are NOT grounded, they simply provide power to whatever the switch is designated for - unless you're using them for relay control.
    You are correct in your statement about what switch is what. TS switch is power in (in from flasher), other two pins are left and right (outbound).
    Other 6 pin switch is for hazards.
    I'm one of the 10 . . . Ha-Ha-Ha.
    Doc
    Thanks, Doc. So, with that I've narrowed down the following:
    There are the two single front left/right turn signal wires and the hazard (red pigtail). What do I do with them? Do they go to the six pin switch?
    Legal: 1/30/2020
    When I added a couple of switches I started drilling w/ a regular bit of about 1/8 inch-slowly. Then I did the rest w/ a step drill-slowly. The step has the advantage of not grabbing the aluminum and pulling the drill toward the dash. It also drilled the aluminum while not destroying the leatherette. I was actually surprised how easy it was to do.
    Thanks for the tip on the step bit. The padded FFR dash has the advantage of having the padding fused to the plastic backing, so it may not get wrapped around the bit. I'll start with a small bit and see how it behaves. If that doesn't work, I guess it'll be time to bring out the razor knife.
    Legal: 1/30/2020
    Senior Member weendoggy's Avatar
    Aptos, CA
    How are the two single L/R wires connected to the existing harness? Are they for your L/R signal light indicator? They might connect back to the ones circled in the harness. If so, that would most likely be your indicator leads. However, they might go to the T/S switch to control that part. It depends on how the harness is wired.
    Your 4-way toggle will be wired with the flasher lead (coming in) connected to BOTH middle teminals and the L/R will be connected to one end of the toggle. Both respectively on L/R side but it doesn't matter which side for each. This will leave nothing on the other end of the toggle (two terminals empty). You'll have to see how you wire the toggle to position it correctly. Otherwise it will be ON in the down position. All you need to do then is move the L/R wires to the other end. I could help more but need wiring diagram info first.
    I'm just a victim of a thousand physic wars!
    www.weendoggy.com/cobra.htm
    Quote Originally Posted by weendoggy View Post
    Thanks, weendoggy. The harness has another set of indicator light wires that I connected to the wires on the speedo gauge. That was clear in the Ron Francis wiring manual. the three sets of wires I've shown in my picture are what is left to go to the switches. The good thing is they are sort of grouped in three different lengths, so with Doc's info above I was able to figure out the hi/lo beam and turn signal switch connections. I believe your info on the six-pin switch will complete the hazard switch wiring. If I'm following you, the two red (pigtail) connectors will go to the two center pins and then the remaining two wires will go to either side of the switch leaving one side (two pins) empty?
    Legal: 1/30/2020
    Aptos, CA
    If you're talking about the top three wires in your picture, with the Red (light color) being the lead from the 4-way flasher, then yes, that is correct.
    Cool. Here is what I have:
    Hi/Low Beam switch has blue headlight dim wire as feed and red low-beam and brown high-beam as the two outputs:
    The Turn signal switch has the gray flasher wire as the feed and the two three-wire bundles (front/rear turn signal) as the outputs:
    And the hazard switch has the red pigtail from the flasher as the feed and the two remaining wires as the output on one side of the switch:
    Now I just need to pay attention to the orientation when mounting the switches to get the correct switch positions.
    Legal: 1/30/2020
    Lost Wages, Nevada
    If you get the switch mounted up-side-down, just re position the outer wire on the switch. The center wire(s) are 99% of the time the feed TO the switch where the outer wire(s) are the outbound circuit to the device you are powering.
    Everything looks correct as near as I can tell from your pics. Test everything before hooking up the car battery, use a 12v lattern battery or low amperage battery charger. Don't want to let any of the "smoke" out of your wire loom.
    Doc
    Aptos, CA
    I'm going to ask, is the H/L toggle handling ALL the load to the lights? If so, you're going to have issues with the toggle overheating and possibly burning up. The toggle is not really strong enough to sustain the load. jmo
    That I don't know. I'll check the wiring diagrams and see if they are relay protected.
    Legal: 1/30/2020
    If I'd taken the time to study the wiring diagrams earlier, I may have answered my own questions on the switch wiring.
    However, the question about relays has me wondering. The only relays in the fuse block are for the horn, cooling fan, and fuel pump. The Headlight power comes through a 15 amp fuse on the main fuse block and into the headlight switch. The light blue wire (Hdlt Sw -> Dim Sw) comes from the headlight switch to the 6 amp toggle as the feed. Is there a relay inside the headlight switch?
    Legal: 1/30/2020
    Aptos, CA
    Most H/L switches have a built in circuit breaker. If it's a small cheap one, I doubt it has one unless its connected to it like some are. If you have nothing, you are definitely running ALL the power through the toggle (not a good idea). It's just too much of a load going through the toggle. If the H/L switch has a breaker, you'll be safe running low beam, but I'd be looking at the high beam circuit too. A lot depends on the rest of you diagram and how they have it wired. Looking at the one above, I'd be leery if the power from the H/L switch is going to the toggle and activating the high beams.
    Many autos have H/L connected via breakers in case you have a short. They will go off/on, off/on, etc. as the breaker cools etc. This is so you still have some sort of lights. However, new cars now have fuses which are OK as well. At least you know you have an issue. Bottom line is they have protection in the switch to compensate for voltage needed. I would put a relay in both low and high side to be safe. I don't trust toggles to carry loads. Even my "DRL" has a relay and it only uses two 194 bulbs.
    Aug 2017
    Southern WV
    Papa
    Did you give any thought to a floor mounted switch, I installed a floor mounted switch and like it. It reminds me of the 1960 era car.
    Rick
    Quote Originally Posted by Itchief View Post
    Papa
    Rick
    I've considered it (still considering it if I need to wire in a relay). I'm not sure about placement given the cramped foot box, but will look at it before making my final decision.
    Legal: 1/30/2020
    Lost Wages, Nevada
    Look on the side of the switch and see if it has an amperage rating printed on it. If it's at least 10 amp rated, you'll be fine. Headlights on HIGH draw about 9 amps (assuming a 55w headlight running at 13.2 v).
    That being said, my personal choice is to run relays on everything drawing high amperage and let the [toggle] switches handle all with low (1 amp max) amperage activation. That is the original design of relays; low amp activation of a high amp load. Most relays are 30a capable with 200Ma draw to activate it.
    FWIW, I have Headlights, Horns, Fan and Starter (push button start) on relays.
    HTH
    Doc
    I'm wondering how many builders wire the switch as the diagram above shows vs. using a relay. I'm sure a relay will be safer for the wiring, but is the kit design really that flawed? If I want to wire in a relay, will this design work?
    I like that the low beams would be on by default and that the high beams would be activated via the switch. I'd use a simple accessory switch instead of the one I have wired up now. Any errors in my diagram?
    Legal: 1/30/2020
    Aug 2017
    Southern WV
    You will not need a relay as long as the switch can handle the load mark at breeze stocks one that should work
    IMO
    I'm not sure if a relay would be safer the circuit has a fuse to limit the current an as long as the wire, switches etc can handle the rated current adding is not going to improve safety.
    I wired my by the diagram
    Lost Wages, Nevada
    Papa,
    Yes, that's a good wiring design for your headlights . . . a failure will still leave you with lo-beams (baring a fuse problem). Plus, with a momentary switch wired into parallel with your pictured switch, you would have a "Flash-to-Pass" function.
    Quote Originally Posted by Big Blocker View Post
    Papa,
    Thanks, Doc. I appreciate the advice and your patience.
    Legal: 1/30/2020
    I'm going to wire in the relay and I also ordered a floor mounted dimmer switch. I have some ideas about how to mount it that I'll be happy with, but if that doesn't work out it'll be back to the dash mount.
    Legal: 1/30/2020
    Jul 2017
    I mounted my floor dimmer switch up top of the footbox and hit it my toes.
    I decided to go ahead and use a floor mounted dimmer switch. Here is a link to the post in my build thread that shows the bracket I made for it.
    http://thefactoryfiveforum.com/showt...l=1#post293666
    Legal: 1/30/2020
