Results 1 to 5 of 5
Thread: Fuel return on Boyd tank
    Jan 2016
    I have the Boyd tank with an in-tank pump, I am running EFI (coyote). My question/concern is this: The fuel return line back to the tank is a pre-welded bung for a 6AN fittting on top of the tank. Will this cause a problem with "foaming" or "airation" in the tank? Any one that has used a similar set up had problems or made modifications?
    Banned
    Loveland, CO
    A proper setup is a 3/8" or 1/4" pipe thread, with a tube or hose, routed to the bottom of the tank. Are you sure that there isn't a return fitting on the large flange for the fuel pump?
    http://www.fueltankparts.com/factory...ealth-efi.html
    Jan 2016
    This is what my tank looks like. Maybe I am mistaken but, the brass fitting is for the vent?, and the open hole is for the return line? Please correct me if I am wrong. If I am correct, the return hole has no tube and will drop fuel in from the top.
    Banned
    Loveland, CO
    I assume that the brass fitting is a vent with roll-over valve. The other bung should also be a pipe thread. You can buy a tube with whatever pipe size this is to use as a return.
    It's also good to have a 3/8" vent hose from the top of the tank to a location very close to the top of the gas filler. It will insure that you can fill the tank quickly without burping fuel.
    https://www.amazon.com/Moeller-Alumi...SIN=B000MTB83W
    http://www.tanksinc.com/index.cfm/pa...prod/prd94.htm
    Jan 2016
    Great info, Thank you for taking the time to help out.
