I know Mike Forte has a hydraulic clutch conversion for the Wilwood pedal assembly and I may end up going that way but it is rather pricey @ $468 plus shipping. Are there other less expensive hydraulic clutch assemblies that will work with the Wilwood pedal assembly? Ease of install is worth paying a few extra $ so you guys say Mike is the only way to go then so be it.
And with a hydraulic clutch do I need to mount all the hardware on top of the wildwood clutch pedal as shown in the manual or can certain items be left off?
Don
