I'm not at a place where I can check my hotmail account to see if I ordered that exact part number or not but I'm 95% certain that's the one that fits them all. The LCA doesn't factor into it. It's between the tie-rod and the spindle. So it should work fine.
To get enough shim, you'll need to order more shims online and use a big bolt (5/8" I think) - I should have pics in my build thread and C.PLavan documented the whole process as well, with pics. Just note that you won't need/want the same number of shims he did unless you are at the R ride height. If you are at the S height, you'll want about 46mm of shims.
