Results 1 to 2 of 2
Thread: Fuel System Connections
    Nov 2016
    Petaluma, CA
    I am in the process of installing my fuel system hard lines. I'm using 3/8" tube in combination with Aeroquip Starlite soft lines. I have -6 AN male fitting coming out of the tank connection (Breeze pn 70736) and make that connection with a female -6 AN fitting to the soft line. At the other end I would prefer to connect the soft line to the 3/8" hard line using -6 AN fittings. I'm not sure how to do this. As well, where the 3/8" hard line connects to my Holley inline fuel filter I am curious how best to make that connection. The fuel filter has 3/8 NPT female threads. Would I use a 3/8" NPT to 5/8-18 inverted flare connecting my hard line to that?
    Any help is appreciated.
    Banned
    Loveland, CO
    You need 3/8" tube to -6AN adapter fittings.
    https://www.summitracing.com/parts/sum-2200077b
