Results 1 to 22 of 22
Thread: Quick Jack Mounting bolts
    Senior Member NICK C's Avatar
    Lawton, Oklahoma
    I am preparing to mount my body but notice some discrepancies in the front quick jack mounting bolts. The rear are straight forward but the front angle cut spacer tubes are all different sizes. Only three are the same sizes and the other five are all different. Am i missing something or am I supposed to take up slack with more washers.Thanks Nick
    Santa Clarita, CA.
    From a Jeff Kleiner post
    Instead of getting too obsessed with the exact dimension just arrange the inners and outers from shortest to longest and position them accordingly:
    RH upper=2 5/8" inside; 3 1/8" outside
    RH lower=2 1/8" inside; 3 1/4" outside
    LH upper=2 5/8" inside; 3 1/8" outside
    LH lower=2 1/16" inside; 3 5/8" outside
    Note that RH=passenger side, LH=driver's side
    Without the spacers and bolts installed the front droops so you'll need to raise the nose a couple of inches to get a straight shot from the body holes to the chassis mounting points. I usually just sit down in front of 'em and push up with my knee.
    Good luck,
    Thanks for saving me a bunch of typing
    Lawton, Oklahoma
    Thanks to both of you. Nick
    Lawton, Oklahoma
    I may be over thinking these spacers. Three of them match your measurements, the others are off. Guess I'll see what's what when I actually start fitment. I know there will be a washer with a rubber surface against the jel-coated body. Is there also a washer on the inside. I pre-fit everything together on the bolt and an inside washer isn't flush with inside of body because the hole is too small tilt the washer. Thanks
    Burlington, WI
    Quote Originally Posted by NICK C View Post
    Do you have an mk4 or 3 ?
    Road Legal August 31, 2017
    Lawton, Oklahoma
    Mkiv
    Southern WV
    Nick
    I used the rubber grommets from finish line to isolate the body from the quick jack bolts
    I had to enlarge the openings on both the front and rear so that the grommets would fit they worked very well for me
    Rick
    Lawton, Oklahoma
    Thanks Rick. I'll look at those.
    MK4 FFR7622 COMPLETE KIT DELIVERED 10/10/11, 429ci BORED .30 OVER, EDELBROCK PERFORMER HEADS, THUMPER CAM, MASS FLO FUEL INJECTION, DUAL CLUTCH, QUICKTIME BELL HOUSING, NITTO 555/DRAG RADIALS, AUTO METER GAUGES, MARCH SERPENTINE SYSTEM
    Sep 2015
    Beachside
    Quote Originally Posted by Itchief View Post
    Nick
    Rick
    X2 on this. They look so much nicer in addition to providing some isolation.
    FFR #8833 289 FIA 3-link
    Lawton, Oklahoma
    Rick do you have any pics of the grommets inside and out?
    Southern WV
    Nick
    Go to **********accessories.com
    Select replica parts
    Then body parts from the main menu
    The grommets are the 8th and 9 th item
    I can send you a pic of them installed tomorrow
    Rick
    Lawton, Oklahoma
    Thanks Rick
    Kevin
    MKIV #8234
    Lawton, Oklahoma
    So are those spacers one piece? And they work with the factory bolts? Looks clean. Thanks Kevin
    So. Bay (So. Calif.)
    Yes. The way I set mine up is with Stainless Steel tubing, ¾ OD, ½” ID, with Grade 8 Bolts, 7/16-14 (.4375), and since the threaded rod is a bit smaller than the ID of the tubing, I used McMaster 2129T15, FEP Clear Tubing for Chemicals 7/16" ID, 1/2" OD as a liner and to keep the assembly nice and snug. I had the tubes polished. The length of the bolt is dependent on how long you want the tube, and how far it sticks out. I ended up shortening the assembly about an inch in the front, and a half inch in the rear, from the FFR setup, as can be seen in the 3rd and 4th picture (barely).
    The second pic shows the difference between the FFR supplied tube, and the 3/4" OD tube. The body pics don't have the ********** grommets, but I have them and they will go in later.
    Lawton, Oklahoma
    Thanks boat. I like the idea of not sandwiching the body between two bolts. Looks good. Good info Thanks Nick
    Spacers are 1 piece. Was installing them when I took the picture. You can see the upper left is a little up & not straight yet. The lip lays flat against the body.
    Pretty sure the bolts are FFR just can't remember now DUH.
    Kevin
    MKIV #8234
    Lawton, Oklahoma
    Thanks Bear. Where did you get the one piece spacers? Breeze?
    Senior Member walt mckenna's Avatar
    Perkasie, PA
    Nick
    Rick
    Has anyone noticed a reduction/elimination of squeaks with these grommets? Mine squeaks sometimes on rough roads and I suspect body to frame rubb someplace or quick jack bolts.
    Mark IV -- 04 Mach1 Donor -- 4.6 DOHC -- TKO 600 -- 3:55 Gears -- 3 Link - Hydroboost PS & PB -- 13" PBR's Front & 11.65's Rear -- Cuesta Wiring -- Thompson Signals -- FFR Radiator, heater, wipers, and catalytic converters -- Metco DS safety loop -- Forte 7/8" front bar -- VPM 3/4" rear bar -- Champ road race pan -- Corbeau A4 Seats -- Nitto NT-05's on 17 x 9's.
    Sorry but I just don't remember. When I started the build I bought a lot of different small pieces from the guys who advertise here if I thought the quality was better than the FFR supplied parts.
    Also made a lot of trips to Home Depot & McMasters web site.
    Kevin
    MKIV #8234
    Jax Beach, FL
    I am also a big fan of the ********** grommets. Especially if you are putting a nudge bar (bumper) on the front, save yourself some aggravation and get them.
