Thanks Thanks:  12
Likes Likes:  10
Page 3 of 5 FirstFirst 12345 LastLast
Results 81 to 120 of 190
Thread: Chris' 289 FIA build, #8833
    Thanks Chris!
    Keep up the good work!!
    Sep 2015
    Beachside
    Reached another milestone today; I disassembled the body buck and officially returned control of my wife's side of the garage. Cleaned of course, sorta...
    This means that I have placed the body on the car for the final time. Final time for me that is, the next time it comes off will be at the body shop. I believe that I could tackle this myself, but I'm not sure I want to. And... I will forever be over critical of my work if I did do it.
    So... I can confirm that trimming the body is necessary as PeteH described. Dropping the body on yesterday took ~20 minutes including removal of the gas cap. So much easier.
    Today was spent reassembling things, hood, trunk and doors. Some minor tweaking will take place, but I'm pretty happy with the rough fit. I'm assembling everything in case I decide to register it in the spring and drive in gel-coat whilst saving for body work/paint. Assembly continues next weekend, followed by the alignment.
    Here are some pics:
    gloves cover the overly long bolts that will be replaced.
    FFR #8833 289 FIA 3-link
    Vermilion,OH
    Congrats Chris,
    It looks great as an almost complete roller. I'm sure you have a sense of satisfaction at turning the corner for the final straight. The more I see them coming together, the more motivated I get to finish!
    Nov 2016
    Petaluma, CA
    Chris, as with Pete...congratulations. It makes me even that much more motivate to move forward. The pictures are really helpful by the way!!
    Millis, MA
    Looks great Chris. We're all chasing you now.
    Sep 2015
    Beachside
    Thanks guys. Lots off ups and downs with this build. I'm sure there are a few "opportunities" left that are lurking, but I think I can handle them.
    Looking forward to seeing some photos of your cars!
  7. #87
    Sep 2015
    Beachside
    Reassembly continues, found myself having "one of those days". You know, those days when you put a tool down, turn around for a second and it's gone. Same with a part or subassembly. Then it pops up when you decide to do something else.
    Today was mostly gremlin hunting in the electrical system. Not sure what's happened, but systems that worked great, no longer do (fan, turn signals, hazards). I did have minor success today, the side marker lights work (for now...), so let there be light.
    Tomorrow is another day...
    Got some more run time in, here's video from last week.
  8. Likes BlueMud liked this post
  9. #88
    Nov 2016
    Petaluma, CA
    Chris, I always enjoy hearing your motor run. It gives me faith!!
  10. #89
    Mark Dougherty's Avatar
    Hershey PA
    looking and sounding great
    The traveling Builder
    717-773-5624
  11. #90
    Vermilion,OH
    Chris,
    Looks and sounds great. Love to hear it run. It's going to be hard to take apart to do bodywork!
  12. #91
    Sep 2015
    Beachside
    Thanks guys!
    Yes, it will be a lot of work taking it apart before paint, but this way I can make sure everything fits the way I would like and all the holes are drilled before it goes. All the lighting is connectorized, so that should go easy.
    Plus it gives me the option of registering it and driving in gel coat if I need to save a bit more for the body work and paint.
  13. #92
    Elk Grove, NorCal
    Looking good! Sounds good!
    Kit purchased: July 25, 2017
  14. #93
    Louisville, KY
    Sounds great! It’s always tough to judge sound and noise levels through video. From what i’ve Been told the 289 sidepipes are LOUD. Has that been your experience? I was already researching welding in some type of muffler.
    2nd 289 Build In progress. 302, midshift T5, IRS, 15" Halibrands
  15. #94
    Sep 2015
    Beachside
    Yes, they are load. Louder than I expected. But, so far so good with the neighbors. For the most part, they all love it and can't wait until it's done. Only had one run in so far, but this guy has a history in the neighborhood shall we say. But it's ok when his little dog yaps for hours on end at all hours. I'm not super concerned.
    I might consider changing them out some day.
  16. Thanks lasse2 thanked for this post
  17. #95
    Millis, MA
    On the advice of Tony at FFR I got a set of cats to use instead of j pipes. I’m going to wrap them in header wrap or somewhat camouflage them. The boys at FFR say this is an affordable way to quiet these pipes, and having heard the showroom car run, they are LOUD. I also have the j pipes if I’m not happy with the look/sound of the cats.
  18. #96
    Louisville, KY
    Quote Originally Posted by chuckster View Post
    Interesting. I think i may go ahead and get the cats and replace the j-pipes. Flowmaster makes an inline muffler that i may weld in as well, but i’ll Try the cats first. I’m a few months away from getting the engine in, so i have some time to figure it all out.
  19. #97
    Sep 2015
    Beachside
    Interesting. Did they give a part number for the cats?
  20. #98
    Millis, MA
    I’ll try tp get that part# for you.
  21. #99
    Millis, MA
    Catalytic converters part #s
    13873. LH side catalytic converter
    13874. RH side catalytic converter
    Hope this helps.
  22. #100
    Sep 2015
    Beachside
  23. #101
    Nov 2016
    Petaluma, CA
    Who is the manufacturer associated with those part numbers?
  24. #102
    Do these black simple side pipes come with the 289 kit? I'm wondering if I can use this same look on a Mark IV?
  25. #103
    Sep 2015
    Beachside
    The single pipes come with the 289 and are stainless. I painted them black since that's the look I wanted for the car.
  26. #104
    Louisville, KY
    I believe those are factory five part numbers.
  27. #105
    Millis, MA
    That’s right FFR part #s. They have a standard fittin for headers on one end and the connector for the FFR side-pies on the other
  28. #106
    Junior Member KW33's Avatar
    Oct 2017
    Atlanta, GA
    Nice video of the engine start. Looks and sounds great!
  29. #107
    Sep 2015
    Beachside
    Couple updates, getting ready to register the car this spring so working cleanup items.
    The alignment is done, I'm glad I went through this myself, it was a good learning experience. I've also mounted all the exterior items and rough fit the doors, hood and trunk lid so that all the holes are drilled before paint. The car will be going in for paint over the winter. To get it ready, I've been disassembling everything and marking some areas that need extra attention. The shop will take the body and chassis, but will remove the body for paint and re-mount it when done. I really didn't want to handle a freshly painted body.
    I've also resolved one of my last gremlins, the hazard lights. Everything worked electrically in the car, but the rear hazards would only work if the brake was pressed. Not a huge deal, but MA has become stricter with inspections and I wanted everything working properly. I tested everything and it appears that the converter has enough voltage drop to not light the LEDs. The LED taillights provided with the kit drop out at under 8 volts which is a significant drop. Activating the brake switch provides enough extra voltage to light the LEDs.
    I also contacted the manufacturer of the converter and they said the units are not compatible with LEDs.
    I ended up purchasing two of these units to replace the converter:
    Wiring is simple, one signal wire goes on the input side. The signal wire on the rear harness attaches to the output side. Use one diode module per side. The brake signal attaches to the other input, run a jumper between the two modules to get brake signal on both lights.
    That's it, problem solved. Fully functional hazards now.
    Now my next big dilemma is color. Originally I wanted Princess (Viking) Blue, then I thought about a black/yellow scheme like csx 2128. Now? Not sure, but I will have to decide soon. Next update will probably be several months from now once paint is done, then we'll see where I ended up....
    UPDATE: 3/2020 The diode approach is quick and easy but the rear turn signals don't function when the brake is pressed. Swapped to this unit:
  30. #108
    Vermilion,OH
    Thanks for sorting this problem out Chris. On to Amazon!
    Did you have to separate the front signals so they do not come on with the brake?
  31. #109
    Sep 2015
    Beachside
    The diodes are there to prevent back-feeding the system, so you shouldn't see that issue Pete.
  32. #110
    Nov 2016
    Petaluma, CA
    Perfect Chris. Placed my Amazon order yesterday. Thanks for sorting this out for us. Joel
  33. #111
    Sep 2015
    Beachside
    New Year, new update. Today was sad, because my garage is now empty:
    But... that means the weather was good enough to bring the car to the shop. Loaded the trailer this morning, it was a balmy 17 degrees:
    Got to drive it around a bit in the process. Really happy with how it drives. Noise is still a bit on the loud side. Might need to do something about it....
    The car is safely in the body shop, they will start in on it next week. This is the same shop that painted the Hot Rod Truck and the red Type 65 for FFR.
  34. #112
    Sep 2015
    Beachside
    Got a nice surprise yesterday from the body shop; pictures of the first round of priming. Next week they will continue on with final fitting then more blocking and priming. Target for shooting color is the first week in March. Getting closer....
  35. #113
    Vermilion,OH
    Looks great Chris, it's getting there. I wet sanded mine with 600 grit this week but notice some imperfections that will most likely require another round of primer/block sand at least on top the front fenders. Taking a halogen light tomorrow for closer inspection in the glare. Have the doors, inside trunk, and hood painted in color and clear coated. Waiting for warmer weather for rest of it. It will take me two long days to do all the striping, color and clear coat I think. The exhaust fan for paint booth sucks heat right out of the building pretty quick.
    Pete H.
  36. #114
    Nov 2016
    Petaluma, CA
    Hey Chris! Great progress!! Both you and Pete are way ahead of me. It's been cold out here and I have been lazy! Still, my motor will go in over the next few days. Your car looks great.
  37. #115
    Sep 2015
    Beachside
    Received another update yesterday. I think I've lost track how many times they have taken the body off and put it on again. Next weekend I will take a drive down there and approve the final paint color. Really getting excited now...
  38. #116
    Chris-
    You must be really stoked! The car looks great, and I am sure you are ready to see some color.
    I look forward to the next update where we get to see how cool the color will be.
    Thanks for the update!
    Nov 2016
    Petaluma, CA
    Looks great Chris....color??
  40. #118
    Sep 2015
    Beachside
    Thanks guys. Going with the Viking Blue. Similar to the FFR demo car, but they used a newer Toyota blue.
  41. #119
    mike forte's Avatar
    Framingham, Ma.
    Hi Chris,
    You've been busy! I guess I'll be seeing you driving in the next few months..
    BTW, Thank you for your business and if you need anything, I'm just the next town away..
    Mike Forte: Forte's Parts Connection / Framingham, Mass. 01702 / 508 875 0016 / [email protected] / fortesparts.com / Facebook Instagram: @fortespartconnection Est: 1981 dealing performance parts to build your dream car. A REAL SPEED SHOP with parts, price & knowledge. Developer of the early Ford & FE Tremec and Mustang firewall adjustable quadrant kits, external slave clutch release conversions & cable release conversions. Tremec Elite, FORD RACING & QUICKTIME DISTRIBUTOR!
  42. #120
    Sep 2015
    Beachside
    Hi Mike,
    Yes, should be soon. Hard to believe it's been 2 years since we picked it up. You've been a huge help, I'll let you know when it's close to being back.
