Thread: Fitech with ZERO rpm on handheld - Won't deliver fuel
    Tybee Island, GA
    Yesterday I was trying to get my car running again, and am having trouble getting a rpm signal to the fitech.
    My blue fitech wire is on the coil negative post, and I'm getting spark to the distributor. White fitech wire is getting voltage during start. I have a summit ready to run distributor with the summit recommended coil.
    It will burn the prime shot, but I can see that no other gas is going into the barrels when turning the key.
    https://www.youtube.com/watch?v=g1kzBhZrdv4
    Videos are at: YouTube Videos
    Copperhill, TN
    Dave, my MSD dizzy has a tach output wire that feeds signal to my FiTech, maybe an option if yours has one
    Good luck,
    bobl's Avatar
    Spicewood, Texas
    Seeing your other thread about the hot alternator brings a question to my mind. Is the battery fully charged? During cranking the voltage may be dropping too low for the ecu to function properly.
    Jacob's Avatar
    Rogers, AR
    Facebook has a Fitech page that is chock full of info on the system and different issues with fixes. You may want to try that?
    MK IV complete Kit - 1st time builder started Sept 2016
    Levy 306
    T5
    2015 Mustang IRS
    Power steering - Levy setup, Breeze roll bars, Thompson trunk box
    fuel injection, powder coating, sway bars, heater, wipers, 17 in wheels
    Tybee Island, GA
    Quote Originally Posted by bobl View Post
    Battery is fully charged with charger hooked up while turning over.
    Quote Originally Posted by Jacob View Post
    Fitech FB Group says that they thinks that the ecu is dead.
    Tybee Island, GA
    After some testing with Fitech Technical Support, I'm sending it back in for ECU repair. I'm actually relieved because I've been pulling my hair trying to find the solution on my own. Hopefully, when I get it back I'll be ready for a gokart (silver lining).
    Senior Member Lowrod's Avatar
    Nov 2015
    Mount Olive AL.
    Keep us up to date, I’m using a fitech unit and hope all goes well with it.
    Jun 2015
    Fairfax Station VA
    Hi Dave,
    Sorry for your bad luck. It would be interesting to find out what caused the ECU to fail.
    MK IV Roadster #8631
