![FormaCars](https://thefactoryfiveforum.com/attachment.php?attachmentid=62553&d=1483735916)
0
0
Toggle Switches
My complete kit came with five, Lucas style, toggle switches. See below.
The first two switches seem to be simple on and off. What are these intended for?
The third switch has "on/on" stamped on the case and three terminals. Intended use?
The fourth switch is "on/off/on" and I assume is for the turn signals?
The fifth switch is stamped "on/on" and has six terminals. Intended use?
Thanks for the help.
Joel
Originally Posted by
japollon
Joel
Joel,
The two On/Off are for accessories of your choosing.
The On/On is for Hi/Lo beam selection
The On/Off/On is for turn signals
The On/On six terminal is for Hazards
You may find this thread helpful: http://thefactoryfiveforum.com/showt...witch+question
I had pretty much the same questions as you.
![Replica Parts](https://www.factoryfive.com/wp-content/uploads/2015/04/replicaparts.gif)
