Results 1 to 5 of 5
Thread: Tire Question
    Brooklyn Park, Minnesota
    Tire Question
    Could someone please state the actual size difference between P275/50R15 and P275/60R15 tires. Are they taller, wider or both and by how much in inches? I am working to replace old BFG TA's on 15" 4 lug wheels. I don't want to change to 5 lug 17" if I can avoid it due to the expense. I have a 12 year old MKII with 1990 Mustang 4 link. The closest replacement tires I can find are 60R and I am trying to determine if they will fit without Mods. I have been a member here form the start and check and read this site everyday but don't and haven't posted often. Thanks for your consideration.
    Flip
    Seasoned Citizen NAZ's Avatar
    See if this link works https://tiresize.com/comparison/
    Good info NAZ! Thanks for the link. Now I need to do some investigation to see if 60's will fit.
    Thanks!
    Try 295/50-15.
    https://www.tirerack.com/tires/tires...omCompare1=yes
    The 275/60s are 28.1 OD vs 26.8 for the 295s. I think those 60s will be way to large and hit the 3/4x3/4 tube that runs out to the door latch
    Yes Craig, the 295/50-15s look like they may be the best route to go. Thanks for your input.
    Flip
