Thread: Source for Sealed/Membrane or Dust Proof Grommets
    Nov 2016
    Petaluma, CA
    Can anyone provide me a source for sealed/membrane or some sort of weather tight rubber grommets in the sizes that are used in the firewall to run electrical wires through?
    Joel
    Banned
    Aug 2011
    Go to Summit's website and search "firewall grommet" They have Daystar/Seals It/Vintage Air/Ron Francis. Pretty much all types even two-piece seals.
    Nov 2016
    Petaluma, CA
    Thanks. I was looking for something that had a more positive seal. Does anyone know of anything like that?
    Have you checked McMaster-Carr?
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Member of the The Gateway Cobra Club
    Ohio
    McMaster-Carr has just about everything you need to build these cars. You could also check your local auto parts store for a grommet. I had luck finding grommets at one. Good luck
    JRL16
    Senior Member Presto51's Avatar
    Catonsville, Maryland
