Results 1 to 13 of 13
Thread: Keith C's 818C Build Thread
    Jun 2017
    I guess I can officially start this. Driver is about 100 miles away. Looking forward to getting started!!! Will post again with some pics!!
    Mar 2015
    Houston, Tx
    Quote Originally Posted by kcarlasc View Post
    Nice! Welcome. What are your plans? What are you doing for a donor?
    Jun 2017
    I have an 07 WRX for a Donor... A shop here in town builds some outrageous Subaru Race engines.. Has a few that have put down over 1000WHP... not going that nuts. Planning a flex fuel 400-450 HP with a STi 6 speed...
    Member jcpresto's Avatar
    Mine is tuned on E85 and puts down 418 to the tires. Good luck on the build.
    Jul 2017
    The Villages Fl.
    I look forward to following your progress. Mine is just 5-6 days away on the same truck. I am using a 2004 wrx donor, which is in the re-build process. Good luck!!
    Jun 2017
    Quote Originally Posted by jcpresto View Post
    Hi,
    what axles did you use? Thinking about some DSS ones.
    Keith
    Senior Member mistasherm's Avatar
    East Central PA
    Keith - what material are you using to coat the aluminum panels and the undercarriage and did you prime the panels with anything before you applied it?
    Jun 2017
    It's Herculiner... I did not prime the panels, probably should have, just rough them up some with sand paper...
    Keith
    Quote Originally Posted by mistasherm View Post
    Senior Member AZPete's Avatar
    I see a dent in your firewall where the bolt for the lower control arm hits it. I ended up drilling a 1.5-inch hole in the firewall so I could torque that bolt, then found a hole cover at Ace Hardware.
    and, nice shop!
    Jun 2017
    I like the cover.. I torqued it before I installed the arm.. But I like the looks of the hole and cover vs. the dent.. May have to do the same thing... Thanks!!
    btw: the spec was like 140ft lbs right seemed so high to me.
    Feb 2013
    Copperas Cove, Texas
    The 140ft-lbs is correct however your suppose to torque it with the vehicle on the ground which is why most people cut the hole.
    -Jason
    Jun 2017
    Good point.. I will have to do the hole..
