Is there any good alternative to using rubber grommets in the firewall and other places to seal the holes where the harness is routed? The holes are 1 1/4" and I would rather not make them larger. Anyone have a better solution? Thanks, Joel
Joel,
I've seen these type of connectors used in custom builds.
https://www.americanautowire.com/get...-the-firewall/
Another cool looking option I found:
http://www.burnout2turnout.com/produ...tor-plate-s18/
http://www.te.com/usa-en/products/co...?tab=pgp-story
Delivered: 6/17/2017
First Start: 12/30/2017
Completed: 12/7/2019
Legal: 1/30/2020
Member of the The Gateway Cobra Club
Another idea is to use the sealed door jam bulkheads like on the Ford truck doors:
Legal: 1/30/2020
Thanks Papa! These are both more of what I had in mind. Just a more finished and professional look I think. Joel
I'm using the American Wire bulkhead connectors that Papa shows in his first post. These are Weather Pack type and look very much like what you would find under the hood of any car and truck made in Detroit. I can highly recommend them as they are a robust design, easy to install, and look professional. But you do need Weather Pack crimpers when working with Weather Pack connectors to make the correct crimp. Yes you could use something else instead of the correct tool but it'd be like driving a nail with a rock.
Deutsch HDP (flange mount with locking nut for the fixed connector).
