I am installing the RT turn signal and have the RF wire harness. I ordered the base kit so I do not have all the extra switches that come with the complete kit. F5 sent me this but I don’t believe it is the correct switch. Can someone confirm. I understand that if I use diodes I need a STSP and if not using diodes I need an STDP. Is the switch I have either one of these?
Thanks Craig
I used a regular on off switch with diodes purchased from ebay, easy to do.
