Results 1 to 5 of 5
Thread: All you guys running Fitech, What throttle bracket are you using?
    Senior Member Lowrod's Avatar
    Nov 2015
    Mount Olive AL.
    I’m installing my Fitech system on an Edelbrock Airgap manifold and need a bracket for the throttle cable.
    What are you using and where can I get one!
    Jul 2014
    Lowrod,
    Not a lot of help and not a great picture but, went with mechinical linkage on my fitech on airgap manifold and had no problems with the route.
    Copperhill, TN
    I’m using a standard one from summit racing with a lokar cable. I’ll look for my invoice if you need it, but it’s just a carb bracket
    I use the Lokar carb bracket, but have to modify it so it does not move under stress. I add a home made bracket to make it more solid.
    Senior Member brewha's Avatar
    Somers, Ct
    I used generic one from Autozone. It needed just a simple modification. It’s worked fine for gokarting but I plan on going to a mechanical linkage is the near future.
