This is actually for my Coupe build, but will post here since this area seems to get more traffic plus they're the same. I've used Russ Thompson's VW based turn signal setup on each of my builds to date. Works great and really makes the column to dash area look much more clean and finished. Very much want the same thing on the Coupe.
A few days ago I contacted Russ to order one for my latest build, and learned what some of you maybe know already. The VW turn signal assembly that is the starting point is apparently in short supply and not easy to find. He has a waiting list and is trying to get more. I'm now on the list. Hopefully he'll be able to find more and have one for me over the next months. No huge hurry. In the meantime, I've been poking around looking at what other options might be out there. Nothing that I've seen yet is remotely as nice. I really don't want the dash mounted switch, even with the electronic timer some are using. I really like the self-cancelling stalk setup, including the button on the end I like to use for the low/high beams.
I know North Racecars has traditionally been another source, but it uses the same VW assembly. I haven't checked with them, but guessing they too may be having trouble filling orders.
Any alternate solutions out there? Maybe someone has one of Russ's pieces laying around they're not going to use??? Thanks in advance.
