Results 1 to 12 of 12
Thread: Show Me Your Column Mounted Turn Signal Setup
    This is actually for my Coupe build, but will post here since this area seems to get more traffic plus they're the same. I've used Russ Thompson's VW based turn signal setup on each of my builds to date. Works great and really makes the column to dash area look much more clean and finished. Very much want the same thing on the Coupe.
    A few days ago I contacted Russ to order one for my latest build, and learned what some of you maybe know already. The VW turn signal assembly that is the starting point is apparently in short supply and not easy to find. He has a waiting list and is trying to get more. I'm now on the list. Hopefully he'll be able to find more and have one for me over the next months. No huge hurry. In the meantime, I've been poking around looking at what other options might be out there. Nothing that I've seen yet is remotely as nice. I really don't want the dash mounted switch, even with the electronic timer some are using. I really like the self-cancelling stalk setup, including the button on the end I like to use for the low/high beams.
    I know North Racecars has traditionally been another source, but it uses the same VW assembly. I haven't checked with them, but guessing they too may be having trouble filling orders.
    Any alternate solutions out there? Maybe someone has one of Russ's pieces laying around they're not going to use??? Thanks in advance.
    Senior Member skidd's Avatar
    Jan 2016
    SA-TX
    Shameless Plug... my totally custom setup. The switch in my case isn't column mounted.. but it could be I guess.
    DIY-SolidState-Arduino-Self-Canceling-Turn-Signals
    Richard Oben's Avatar
    Kansas City MO
    Richard Oben (me), North Racecars and Russ are old (1998) Friends and we got our switches from the same place. Which was all good until the unfortunate passing of the supplier. For now we at NRC have stopped making the turn signal set up. Russ and NRC use different approaches but the same base switch. For now everyone will have to be patient as Russ is working on a new supplier. Hope this explains some stuff for everyone. As for the coupe we always sent a MKIII - IV version for the new coupe we would have to see one, but I doubt it is different. HTH, Richard.
    Dec 2017
    Southern Ontario
    Not really sure which VW hub you guys start with, but here's a link...
    http://www2.cip1.com/ProductDetails....D953%2D513%2DF
    They must be one of the biggest VW parts suppliers on line.
    Higgy
    Quote Originally Posted by Richard Oben View Post
    Thanks for the information. Patience? Not my long suit. The Gen 3 Coupe is different than the Mk3/Mk4 Roadsters and maybe previous Coupes (I don't know) but Russ is on that. Just needs the base parts.
    Quote Originally Posted by HiggyMK4#???? View Post
    Higgy
    That's just the switch itself. Russ starts with the entire hub including the switch. Two listed on that same website. Both show out of stock and "hard to get."
    I have the GEN 3 setup from Russ. Much different mounting system from all the previous cars.
    OK, now you're just showing off. I think that was a shipping error. Was supposed to come to my place.
    Copperhill, TN
    Richard,
    Too bad about the loss of your supplier, I just plugged the NRC switch on the other forum. Hope you find a new supplier, you make a great unit
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Maybe try Cobra Restorers or Hillbank for something a bit more original looking.
    Later,
    Mk3.1 #7074
    Super Moderator
    Richmond, ca.
    Yes, this past year has been tough, getting the correct VW switch for my system has really been a pain since my normal source ran out. The good news is they are doing another run the first of feb. with the switches due 6 weeks later. In the mean time I have been
    buying everyone out. Several places have taken my orders saying "no problem " getting me more only to find out they can't. The Cip site was getting them from my source I believe and I bought all they had left a couple months ago.
    I have lots of guys waiting and work daily looking for switch sources. I have a couple due in today or tomorrow and if they look good I'll order more. The main problem is whats left out there are extremely expensive or junk.
    I'll keep you all posted
    Member JRD56's Avatar
    Oct 2014
    Olathe, KS
    Hi Paul, I built my own from parts from a 66 Mustang. I've restored several mustangs over the years so I had the parts on hand. It take some customizing to do this. The back of the FF hub must be turned down and some roll pins installed to act as the cancelling pins. You then have to mount a 1-1/2 ID tube, install a nylon bushing and shorten the mustang housing about 1/2". Then of course you have to interface the mustang switch electrically. Mine works fine. It was a lot of work and I'd likely not have done if I didn't have the parts on hand and access to lathe. Turn Signal 2.jpg
    Purchased and un-assembled Mk3 in 2016. 5.0, Aluminum heads, Performer RPM Air gap, Quick Fuel 650 carb, BBK headers T5, 3.55 rear solid axle, Koni Shocks, PS with Hydra-boost. Also own two restored vintage Mustangs, two Model A fords, 1941 Chevy truck and several other hot rods.
