That angled panel in the rear of the cockpit forms part of the rear wheel inner wheelwell. You'll need a good seal along this edge to keep the outside from coming inside. Especially when you get caught in wet weather or wet roads. I brought the bulb seal across the top and down to the frame by the door latch bracket. After the body is on for good, any little gaps or opening can be sealed up with caulking.
Ok, just to be sure, you are saying to pull the bulb seal all the way down to the black frame you can see in the photo, correct?
