Is an AC Kickoff something that most buiders use when wiring their cars?
I weird mine so that there is a switch for the main heater/ac off/on, and one for the ac compressor. Because you can't reach the dash when strapped in.IMG_7697.JPG
Yellow heater/ac, blue ac pump, red high beam( lights on switch )
You still need to control the fan speed and temp setting, so I don't see the point. It's also why I installed a retractor on the Y strap of my dual shoulder straps. I got tired of not being able to reach the dash. Better to move the whole control unit within reach, if the capillary tube is long enough.
