I've installed the CobraHeat heaters in my leather roadster seats and will be using the Breeze inclined seat mounts. I plan to use the heater wire as the +12v source. I'd like to install the switches in the dash, so I'll need to extend the wiring between the seat plugs and the switches. I'm thinking of running the wires along the corner of the floor and trans tunnel or along the edge of the floor and wall on the outside of each compartment. I see some going through the trans tunnel wall, but prefer to not have additional openings unless that is the best routing.
