Results 1 to 8 of 8
Thread: Steering Wheel Center Cover
    Senior Member JIMOCO's Avatar
    Camp Hill, PA
    I know I saw a thread on this before but cannot find it. I removed my steering wheel and reinstalled it on Saturday. Now I find that the center steering cover will not snap into the boss. It feels like air pressure is keeping it from seating. When I originally installed it I did not have the FFR badge installed. Now it is preventing air to escape. Does anyone have a solution that will not visibly damage the steering wheel, boss or badge?
    Mk4 Roadster, Picked up complete kit 8/22/14. Most FFR options except Wilwood brakes and IRS. First start 11/11/14. Go-kart 3/8/15. 347 Stroker, TKO 500, 3-link/3.27 rear. PA street legal 7/29/15.
    slpro1207's Avatar
    Moorpark, CA
    I had the same problem. After looking closely I noticed that the steering wheel was installed just enough off center to creat a lip on one edge that kept the center piece from pushing in. Loosened the six screws and centered it up and it popped right in. Hope this helps.
    MK4 delivered 2/24/2017. Complete kit #9023,IRS, Power Steering, Leather, heater, 17" wheels, sway bar ft & rr, tremec 600 and Gordon Levy Racing SBF 427. First start and go kart 8/19/2017. Graduated 1/15/2018
    MK4 #9230 complete kit delivered 1/27/2018. IRS, PS, leather, Tremic 600, SBF 427. Graduation 10/15/2018
    MK3 #5253 donor bought unfinished. SBF 331, T5 Trans.
    Apr 2014
    I drilled a 1/16 hole in the hub.
    Raleigh, NC
    Yep, drill a small hole in the hub under the emblem.
    Jul 2017
    I drilled a small hole in the horn button just above the oring in to the center to let the air out, makes removal easier also.
    Senior Member dpariso's Avatar
    Beach Park, IL
    anyone have a pic of a hole they drilled in the hub? Im having a problem imaging where to drill
    Alliston, Ontario, Canada
    I don’t have a pic, but I also drilled one through the hub, off set all the way to one side, so it comes out in between the nuts on the back.
    Apr 2014
    I drilled mine in the back of the hub facing the dash board between the bottom two bolts.
