Breeze sells (or they did) wedges and spacers to make everything fit. We have shimmed the motor mount a lot of times also. It is a fixable situation. In the case in the picture make sure the splash guards are installed. Also the body is NOT centered over the hood opening it is centered by measuring the shock mounts to fender. HTH, Richard.
Richard Oben FFR builder
www.northracecars.com
