Thread: Car pc stuff
    Member afourcault's Avatar
    Oklahoma City, OK
    Car pc stuff
    some of you were asking about this in one of my other threads. well i pulled together everything that i had on the car pc that i plan on installing in my current car( 96 piece o crap eclipse) and then eventually transferring over to the GTM once i get that close/finished.
    Recommended for the basic pc user (knows how to safely install software and follow directions) starting from the battery through to the interface and link to where each is found:
    Automatic Startup and Shutdown Power Controller - $39.99
    http://www.mo-co-so.com/MPEGbox-uSDC-p/mcs-atx-usdc.htm
    4th Generation Centrafuse Complete CarPC + auto switch for back up cam, best screen, and assembled in a black double din frame - $1,989.99
    http://www.mo-co-so.com/ProductDetai...CS%2DCBS%2DTK1
    BU-353 Weather-proof GPS Receiver - $35.99
    http://store.mp3car.com/BU_353_USB_G..._p/gps-002.htm
    External USB Slot Loading DVD Combo Drive - $64.99
    http://www.mo-co-so.com/USB-Slot-Loa...p/mcs-cmbo.htm
    Directed HD Connect Car Radio - $74.99
    http://www.mo-co-so.com/Directed-DMH...cs-dir-hdr.htm
    HD Radio PC Interface - $39.99
    http://www.mo-co-so.com/HD-Radio-to-...cs-mjs-hdr.htm
    USB Tire Pressure Monitoring System (TPMS) Version 2.20 4 Sensor Kit - $289.00
    http://store.mp3car.com/USB_TPMS_Ver..._p/com-090.htm
    Phoenix Audio MT107A Automotive Microphone - $149.99
    http://www.mo-co-so.com/Phoenix-Audi...-pat-107-a.htm
    28mm Rear View CCD Camera with Night Vision LED's - $49.99
    http://www.mo-co-so.com/28mm-Rear-Vi...-cam-25-nv.htm
    TDA7850 Internal 4 x 50W Quad Bridge Power Amplifier - $79.95
    http://store.mp3car.com/TDA7850_Inte..._p/com-140.htm
    recommend for the advanced pc user (someone who has experience building pc's) starting from the battery through to the interface and link to where each is found:
    Barebones 4th Generation 2.0GHz C7 Car PC - $259.99
    includes power supply, motherboard, cpu, ram, bluetooth
    http://www.mo-co-so.com/product-p/mcs-bb-20.htm
    1TB 5400 RPM 8MB Cache 2.5" SATA 3.0Gb/s - $109.99
    http://www.newegg.com/Product/Produc...D=3087823&SID=
    Internal USB B/G Band Wireless Module - $14.99
    http://www.mo-co-so.com/Internal-USB...mcs-wif-3c.htm
    Double DIN Lilliput 669GL-70NP/C/T 7" Touch Screen Monitor with HDMI, DVI, VGA, and RCA Inputs + high brightness optically bonded transflective sunlight readable upgrade - $684.99
    http://www.mo-co-so.com/ProductDetai...LIL%2D669%2DDD
    Centrafuse Auto Navigation Edition for North America - $116.99
    https://www.centrafuse.com/ProductInfo.aspx?pid=129
    granted this is a lot of information and a crap load of links but its not all that there is.. like i said this is what i recommend.. ultimately my advice for you is to shop around.. ive tried to compile the most advanced products to include for this list at the lowest price. but there could be better gear/prices out there.. take a look hope.
    i have inspired someone
    Though you may try, you cannot break me. I am all that you wish you were but will never be.
    my prebuild/idea log
    Fort Lauderdale Fl.
    Like chinese to me..................I'm getting old!
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    Oklahoma City, OK
    its not that confusing.. for the top setup its just plugging in usb connector(like putting in a thumb drive) and running some cables. the top project is so easy that if you can surf the internet and can build a component car (basically if your on this forum) you can put a car pc in your car! and if that isnt simple enough there is even another solution out there that is as easy as replacing a stereo deck and it can be found here http://www.qualitymobilevideo.com/cpc1000.aspx . its an all in one in dash unit
    Senior Member VD2021's Avatar
    Central, FL
    A,
    Are the reverse camera inputs directly connected to the double din monitors and activated with reverse regardless of the monitors status? If there is a double din with that capability I will be leaning toward a carputor set. That way I can start with a minimum setup and built or revert to a double din head unit.
    R/s
    Vidal
    CURRENT STATUS: Interior Rework and Bodywork.
    GenII GTM #331. Delivered (23/9/10)
    BUILD LOG AND WEBSITE:
    http://gtmbuild.weebly.com/ .
    Oklahoma City, OK
    Quote Originally Posted by VD2021 View Post
    A,
    It works if you have the car pc come on with ignition/acc which is easy to do
    Oklahoma City, OK
    A,
    Central, FL
    Quote Originally Posted by afourcault View Post
    Is the video fed directly to the monitor or does it have to go thru the PC?
    R/s
    Vidal
    Oklahoma City, OK
    Monitor
