Hi, RJD,
The photo, below, is looking down on the e-brake setup on the bracket. There is sufficient room for the bolts to clear:
Note, however, that I attached the e-brake as shown in the manual.
Some builders have noted that attaching the e-brake in that way increases the interference of the handle with the cockpit aluminum side (I cut out some of the Al to make room for a bolt). A remedy for some has been to raise the e-brake handle by re-positioning the front 'L' bracket (i.e., the front and rear 'L' brackets would have the same positioning). If you did that, I think the extension arm bolts might hit the bracket.
-Bruce
