Results 1 to 9 of 9
Thread: Under car exhaust
    May 2016
    Under car exhaust
    Is there enough clearance for a full under-car exhaust? Seems like a good way to prevent toasted ankles.
    Senior Member Todd Buttrick's Avatar
    Give this search a try. Tons of great info.
    Several fellows have done very nice under car exhaust systems and have done so using Spintech Low Profile mufflers:
    https://spintechmufflers.com/muffler...file-mufflers/
    Mar 2017
    Spicewood, Texas
    I did mine with spintech mufflers and oval pipe. With the new IRS it is nearly impossible to exit in the rear. Mine just exit in front of the rear tires.
    LS1, TKO600, IRS, no scoop, undercar exhaust. Delivered June 14, 2017, First start December 31, 2017, Registered and Titled Sept 12, 2019.
    Senior Member Duke's Avatar
    Taxachusetts
    Yup, there's room.
    Copperhill, TN
    I did mine with spin tech 7000 series mufflers and 2 1/4 inch pipe, went all the way out the back. Worked great
    Isn't I Great When A Plan Comes Together?
    A Plan = Factory Five Forum Members
    Sacramento CA
    Maybe overkill or impossible, but could you run two smaller pipes down each side and a collector at the muffler? Maybe it would not help at all but it would seem to give more room underneath.
    Copperhill, TN
    I think overkill, I’m using 2 1/4 round, and haven’t had any problems. It hangs just below the floorboards, maybe 3/16 clearance.
