It was 60 degrees here in Southern WV today so I just had to get the car out for a ride
After about two hours I came back home and parked in front of the garage and came back out a few minutes later and the car wouldn’t start fuel but no spark changed the coil no luck Checked the resistance through the module and found a open circuit no change when then cranking the motor
I have to count myself as lucky because it failed in the driveway
I will order two pickups and keep one and some tools in the car in case it happens again
Rick
