Results 1 to 4 of 4
Thread: Fast Fuel Injection
    Senior Member EZ$'s Avatar
    Feb 2014
    San Ramon, CA
    Fast Fuel Injection
    My question is that I'm having some trouble figuring where to put the control box for the fuel injection. I'm assuming that it needs to be accessible, (might be an incorrect assumption), but what options for location are possible? If you've used a FAST system, what was your solution?
    Thanks for any help.
    Rick
    Member Toy4me's Avatar
    Voorhees NJ
    I put my EZ efi 2.0box under the passenger seat. It is far enough back so i can see all the lights and stuff. I ran the big harness through the side of the tunnel right in front of the seat.
    Feb 2014
    San Ramon, CA
    Toy4Me, thanks for the idea. Sounds like a safe place. Just curious. Do you have a seat slider on the passenger seat, or is it bolted directly to the floor? Did you have to provide any additional height to the seat to give you clearance, or did it fit without issue?
    Rick
    Voorhees NJ
    No seat slider on passenger side. I have Kirkey high back seats so the brackets provided the needed “lift” for clearance over the box. I should have a picture of it somewhere with the seat out. I’ll try and dig it up
