Results 1 to 10 of 10
Thread: Replacement distributor for MSD ready to run
    Aug 2017
    Southern WV
    I need to replace my MSD distributor anyone have a recommendation
    I would like to have one that doesn’t require a separate ignition box
    Rick
    Pertronix. They do have a series that uses a box, but the Flamethrower series does not.
    http://www.pertronix.com/
    Rotonda West Florida
    you want a "HEI" type
    Mark Dougherty's Avatar
    Hershey PA
    Stay away from the flame thrower I have had no luck with those
    The traveling Builder
    717-773-5624
    Senior Member frankb's Avatar
    Feb 2014
    Marana, AZ
    Ordinarily, I agree with Mark D (above), but in this case I will refer to my experience with Flamethrower...I have run this type of distributor in my last two engine builds and have had no issues with either. The first (in a Mustang with a 408C engine), I had lots of ignition issues (failures, really) until I replaced the distributor with a Pertronix unit. With FFR 8317 (my current build), I went directly to the Pertronix unit and have no issues. Of course, be sure that the distributor gear is compatible with your cam gear, no matter what you choose!
    FFR MK4 #8317, 393 Cleveland, Lunati VooDoo solid roller, CHI 3V heads and intake, TKO 600, Std roadster seats, 8.8 3.55 diff, 17" Halibrand replica wheels, Ford "Magnetic Metallic", silver ghost stripe. (Sold 10/16/21)
    Quote Originally Posted by Mark Dougherty View Post
    I understand they are very picky about how they are grounded. On the other hand, I have experienced a few MSD and Ford TFI failures... so what is suggested?
    bobl's Avatar
    Spicewood, Texas
    Take a look at DUI products. More money, but I've had great luck with them and never seen anything negative posted about them.
    mcwho's Avatar
    DeBary - Florida
    Are we talking about MSD Model 83521?
    Baghdad Bob
    Aug 2017
    Southern WV
    I have an msd 8595 for a 390fe
    I had a Mallory distr. in my coupe ... ended up failing when the pin holding the cam gear/to distr. sheared. Replaced it with a stand-alone MSD and had no more problems. 422" Windsor motor.
