Results 1 to 4 of 4
Thread: Manifold for 460 SCJ
    Dec 2011
    Saratoga Springs, Utah
    I have a 460 SCJ engine with aluminum heads M-6049-SCJ. The stock manifold sits to high to close the hood on my MK4 roadster. The Torker II is the right height but the ports are smaller than those of the heads. Have any of you found a solution for the particular application?
    MK 4 Roadster #8195, 460 Super Cobra Jet Engine, Wilwood Brakes, IRS, TKO 600, 18" Halibrand Wheels
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    Enough meat on the TorkerII to do some "port matching" and hog it out??
    John D. - Minneapolis 'Burbs
    Mar 2013
    Medway, MA
    Time for a "Super Snake" hood mod??
    Dec 2011
    I'm not in favor of a hood mod so it looks like its going to be port matching.
