Results 1 to 12 of 12
Thread: Steering Bind Problems
    Senior Member TomH33's Avatar
    Nov 2016
    Parker,CO
    Hi
    I have run into binding on the u-joints because the angle is to severe. It seems there needs to be a third bearing to eliminate the binding. I have the FF Unisteer kit and bought the very expensive u joints from Unisteer. I have gokarted the package and the steering bind every rotation. Has anybody had this problem and how did you fix it. Steering2.jpg
    Thanks TomH33
    Member tcollins's Avatar
    Oxford, Michigan and Scottsdale AZ (winters)
    I don't have a good picture of that area on the finished car, but I added an extra joint, primarily to get around the coyote headers. It seems to turn fine without binding. I don't recall buying extra joints, I thought everything to do this came with the kit? I welded the angle iron to the frame but others, with powder coated frames, have bolted on pillow blocks to mount the bearing in this general location.
    Here is a picture of the bolt-on pillow block if you prefer not to weld.
    May 2016
    North of sacramento Ca.
    I spent time and got joints at 30 degrees, but that is with third bearing.
    Ol Skool
    upstate NY
    The angle on that input looks pretty severe, but recheck the last one at the rack. It appears phased 90 degrees to what I would expect.
    Prairieville, Louisiana
    Make sure the steering shaft isn’t too long and sticking too far into u joints either. That will make them bind when the u joint hits the shaft end that sticks too far out.
    '33 Hot Rod
    MK4 Roadster
    Senior Member JOP33's Avatar
    Haslet, Texas
    I think I remember something in the Steering Column instructions about "phasing" all the joints as well.
    Senior Member TDSapp's Avatar
    Frisco, TX
    That is what I had a problem with at first. The shaft going up into the last joint at the steering column was too long and was hitting during the turn.
    I also noticed that the u-joint right at the firewall is a little away from the bearing face. I recall the directions said to make sure it was flush on the bearing face.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    Second that - it should be touching, and make sure you use just a very short grub screw (no locking nut on it) on that end of UJ so it doesn't touch. But your UJ's are way different to what I got on #997. Ironically in this very early mockup shot, my UJ isn't snug up to firewall either.. it is now, but no pics.
    Frisco, TX
    Here is a picture of mine that I took when I was figuring out how much I needed to cut off of the rod.
    I also had the set screw wrong in this picture and was not using the small one they provided.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    Nov 2016
    Parker,CO
    Thanks You all SOOO Much!! I think the third bearing is a good solution. I will double check the phasing and the shaft length for interference.
    Thanks Again
    TomH33
    Stillwater, NY
    I think the guys hit the nail on the head, it doesn't look like you have the correct joint at the firewall. Unless you have a Coyote or other engine than needs extra clearance, the third bearing is unnecessary.
