I just loosely installed the chrome steering column (upgrade) - and this may be premature but the brake arm hits one of the mounting bolts (closest to the firewall) when pushed in. Again, no fluid is in the brake lines yet (no brake resistance) so maybe the brake pedal will never be depressed that far to even hit the bolt. Also assuming column is mounted correctly - seem only one way, but???
Walter
