Thread: Why can I not make these adapters fit?!
    I have spent two days trying to get these adapters on the end of the coolant pipes. I have tried everything I could find on the forums from heat guns to lubricants and I cannot get this adapter on! I am also concerned that when I do, I will not get the connector over the adapter. What am I doing wrong here??! The manual makes it sound so easy!
    wallace18's Avatar
    Trenton, Florida
    I have used windex and had no problems. Done it many times.
    Mark Dougherty's Avatar
    Hershey PA
    wd40
    that is my weapon of choice
    The traveling Builder
    717-773-5624
    Baldwinsville, NY
    That looks like the adapter that is not used. My kit had two adapters, one shipped inside the other. The inner was not use and that looks like what you have. There should be adapters that fit over the one pictured.
    Senior Member Blwalker105's Avatar
    Throw them away, go to your local auto parts store and buy a couple generic radiator hoses, cut them up to fit your needs and you will be much happier.
    Feb 2014
    Asheville, NC
    Quote Originally Posted by RDRP View Post
    This was my experience. Turbo Subaru hoses are 0.5" larger in diameter than NA Subaru hoses if I've read correctly
    Frank - Build thread
    Bowling Green, KY
    I mixed up a Dawn/water solution.
    QC, Canada
    Quote Originally Posted by Blwalker105 View Post
    Absolutely! OR if you want to spend more money buy some quality silicone couplers. I didn't use any of the provided couplers.
    Tracked May 27/July 26, 2017
    Build Completed Winter 2021
    Thank you, everyone! You have made my life much easier!
