Looking into an option for the 818. Does anyone know if the Audi 01E 6 speed FWD transmission from the Euro diesel would mate to the 3.0T from the 2010+ cars. CEL are of no concern, but the factory ECU would need to run the engine without inputs from the wheels/transmission. Other solution, mate the 3.0T to the wrx trans via adapter and only use front output shafts...(not preferred)
http://advancedautomotion.com/shop/p...products_id=29
Engine would be 2010+ S4 3.0t with OB4 Transmission - other option is to lock the rear output but I don't know if the trans would support 350-400hp that way.
I am trying to figure out if the engine trans combo will work. The engine will fit, but I need to figure out if the transmission will fit and axles align within tolerance.
Sum it up ---
Audi 3.0T Engine
Tranmission - Audi FWD 01E, Audi AWD OB4, Subaru with adapter
