I've been following the manual except for right now while I'm working on the wiring.
I wanted to see how much room I'd have with the tranny tunnel and the floors sitting in place to hide some of the excessively long wires.
I can't get the L & R floor pieces in.
I can see that without the firewall installed the front vertical edges would fit thru the frame opening allowing the back of the floor to drop in place.
I guess I could just lop off the vertical pieces and then use some angle aluminum to re-attach it.
Did any of you have this problem?
