Thread: Broken stainless steel exhaust
    Aug 2017
    Southern WV
    I wanted to check and see if anyone else has had an issue with the stainless steel exhaust breaking
    Mine cracked and broke at the flare where the muffler starts
    Rick
    May 2016
    Mine broke on my Mrk IV roadster passenger side, Coyote 5.0. Turns out that under heavy acceleration the twist in the motor was enough to crack the weld at the flare on the J pipe at the output of the shorty header. Turns out where the side pipe exited the body there was not enough clearance keeping the pipe from moving freely with the motor. Just had it repaired by my local welding shop cost $35. Hopefully this helps.
    Hotrodder427 (My Pal Donny From My Hometown of Slidell) had his drivers side crack where the turn out meets the muffler.
    Factory Five Replaced The Piece!
    Yea Factory Five Customer Support!
    His car can be seen at the end of this video, but not the muffler issue:
    https://youtu.be/Vhbftk4AP4k
    FE 396 with an IRS rear with Wilwood Stoppies.
    Aug 2017
    Southern WV
    Thanks for the information
    I’ll give them a call in the morning and see what they have to say
    I took the broken one to a fab shop to see if they could be repaired m
    Rick
    Aug 2017
    Southern WV
    I contacted factory five this morning and they are going to send me a replacement
    It’s hard to believe this level of customer support
    Many thanks to Dave Smith and the folks at Factory Five
    Rick
    Kirkland, WA
    I've been repeatedly surprised with how quick they step up when there's a problem. Customer service you won't find anywhere else.
    Mk4 #8861 Complete kit. Delivered: 27 Apr 2016, currently a roller.
    Gen-2 Coyote, clutch, TKO600, midshift, and solid axle from Forte. Many pieces from Breeze and Replicarparts.
