Who has been able to install the optional steering wheel and hub so the horn works? There are some very good posts from a few years ago using different hubs, but i have not found any using the one you buy from ffr.
I have the ffr hub and a different momo steering wheel. The hub retained the auto cancel blinkers and I don't recall it being difficult to get the horn to work, although I don't remember the specifics of it.
I have and had zero problems. I like how it retains the T/S cancel feature. It is very straight forward,IMO.
Thank you for your responses. I have the hub installed so the turn signals cancel etc. My problem comes from limited experience for one, and I cannot understand how the wires hook up. Red/Green goes to one spade connector, but what goes to the other? Any help is very much appreciated.
You guys motivated me I guess. I just got it all hooked up and the horn honks!! Success!!
No photos, but: Find the Red/Green wire in your steering column. Attach that to the spade connector in the middle of the back of the horn button. That's it. Your steering column is ground, so when you attach the wheel, it honks. I googled "momo steering wheel install subaru". That makes it pretty clear.
