The CNC Triple Reservoir fits snugly on the DS frame triangle. My rivnuts are a little off so it is slightly uncentered in the space, but works great. I made a backer plate to cover the rear of the reservoir mount and to improve the mount strength. There will be a few rivets mounting the mounting plate to the frame that are not seen. I plan on sending the reservoir out to powdercoat. You can see by the tape on the engine bay frame rail tat the Coyote is a very tight fit requirin some twistis and turns to get it in.
Dlirium, I haven't started electrical yet. I think I will mount the ECM going thru the center of the firewall with the rear extending toward the cabin. This is new to me, so any input is welcome.
