Too many cylinder head choices
Hi Guys,
Unfortunately I am going through a rebuild on my 87 302. It is a stock rebuild, but instead of reusing the gt40p heads I have, I would like to get a set of aluminum heads. There are a ton of options out there. I am looking for an option that doesn't break the bank because I am also going to be purchasing a different carb. The cam I currently have is a b303. I know there are much better options out there, but I plan on sticking with it. Has anyone had experience with any of these heads?
NKB heads - https://www.skipwhiteperformance.com...ord-274_86457/
Promaxx - https://promaxxperformance.com/product/maxx-180-sbf/
Blueprint - https://blueprintengines.com/collect...ount-assembled
The Blueprint and Promaxx appear to be the same casting, although the Promaxx claims to have hand blended bowls. The price on the NKB's is silly and claims to use great components. I am unsure what components Promaxx and Blueprint use.
Anyone have any experience with these heads or can offer other suggestions? Much appreciated!
Scottie
Hey Mr. Scott,
We all know that I'm a Chevy fan; however, most folks don't know that I'm also a fan of Dart products too.
With that said you may want to look at Dart's goodies too, specifically their aluminum Pro-1 series:
http://dartheads.com/dart-product/pro1-20-195cc/
Finally, remember that engines with a smaller cams that have great heads, when properly sized, can surprise the heck out of you.
Good Luck With Your Upgrade!
Hey Steve,
Thanks for the suggestion! I have seen some great tests on the show engine masters with big heads and small cams.
Unfortunately those dart heads are going to be a little out of the budget.
What about the Ford Performance X-heads?
Originally Posted by
scottiec
Hey Steve,
I hear you on the budget since mine was blown to smithereens when I had to replace my block.
Any thoughts about maybe going with the Dart Iron Eagles instead?
I'm all iron (SHP Block & Iron Eagle Heads) so going IRON might be an option; however, you need to keep the compression below 10 to 1 if you want to run on pump gas.
Again, Good Luck & Keep Us Posted!
I like Edelbrock or AFR. Those heads you listed may be fine, no experience with them. Just make sure the exhaust port is in the stock location, allowing use of your existing headers. Mike Forte might have some good advise. He deals with parts on all levels and can relate to your cubic inches, cam, intake, etc. Nothing like experience.
Steve to be honest I didn’t consider iron. That is still an option for sure. I will look into those
davekp
When I looked at the gt40x heads I recall the chamber size being a little bigger than I would like. Also, they don’t seem to have as good of a bang for the buck factor. I was seeing them for around $1300.
Railroad
I’ll give mike a ring. I bought most of my stuff from him to begin with
Edelbrock E-Street aluminum cylinder heads.
DavidW
Apparently they are only for flat tappet cams. Which is alarming. I tried to call Edelbrock yesterday but couldn’t get anyone on the phone. They seem like a great choice.
My engine builder used E-Streets on my 347 and a ton of his other engines. Said the castings are excellent - only issue is that the springs need to be tossed in the garbage right out of the box. They are prone to breaking (all over the mustang forums). I have upgraded springs and use a roller cam.
I bought a set of E-Streets before being informed. I called Edel and was told it was an economy package to compete with the China imports. The springs are not for hyd roller lifters, per Edel. I would question the valves also. The castings do look good and did not require more than a tootsie roll cleanup. I lapped the valves and changed the springs. The spring pockets are too small for standard small block springs. There are some LS-1 springs, I think that make a good replacement. I bought another brand, X70 or something like that, too long ago for my memory. Bottom line, you need to get a good deal on the E-Streets, since you will need to add springs and minor labor to get them to a dependable level.
My heads are still on a bench, so I cannot comment on performance.
Railroad
This is exactly what I have read. Crazy for 1000 bucks you still need to do stuff to them.
scottiec
I think you can still get the E Street Heads from between $500 - $600, I haven't been in the market for some time. They will save you some money and yes you will be required to do some work to them if you want performance. Here is a poor shot of my motor results with E Street heads.
scottiec
Reason: duplicate post for some reason
That’s some good power davidw. An assembled set sells for $9xx
UPDATE
I decided to just spend the extra bucks and go with trick flow twisted wedge track heat 170cc heads. Thanks for the advice everyone
scottiec
UPDATE
Mr. Scott,
Do those heads require special pistons because of the altered/non-stock valve angle?
Sorry to ask, but this Chevy Guy just wanted to know since I'm far from Ford Savvy!
GoDadGo
Mr. Scott,
They do once you surpass a certain lift and duration. With my b303 cam, I’ll be fine. But of course I will check PTV
GoDadGo
Mr. Scott,
Yes.
scottiec
Also yes - you might make it with a B303.
mike223
Yes.
Yeah I just called them as well. They said they have seen guys get away their stage 2 cam with out the TW pistons. But like I mentioned, I will absolutely be checking. Also for anyone that needs to measure PTV clearance, it's not necessarily the lift that causes the issues, it's duration.
Thanks for chiming in Mike!
The most expensive heads are the cheap cr-p that breaks a valve and trashes your engine. Buy good heads and be done, I really like my AFR heads from Ford Strokers.
rich grsc
Absolutely excellent advice.
Most of the off the shelf heads on the market will perform close enough to the same to not matter. The separation comes at the upper power levels, and high rpm's. For street driving, you won't really notice the difference between one and the other.
On the name brands, the castings are all about the same. so don't sweat those differences, and don't fall in to the advertising hype that all companies put out.
The big difference is in the components: springs, locks, valves, retainers. This is where you need to spend the money on quality components, and this is the difference between a $1500 and $1000 set of heads.
Bob Cowan
Totally agreed. That’s why I went for the truck flow track heat with better valve springs
Bob Cowan
I have used several sets of the Trick Flow heads with great success.
wallace18
Glad to hear. In the tests I have seen, these heads put down some really solid power
wallace18
Any thoughts on the Blueprint HP9008 heads?
davekp
Dave, see my first post. They were an option
As I started reading this thread I was thinking "no, don't do it, don't buy cheap heads".
I am glad to see that you made a great choice.
I have TrickFlow heads with Pac Racing springs and they are awesome.
Avalanche325
Dude they just came in today. So beautiful looking lol.
scottiec
Congratulation & I'm Sure These Heads Will Be A Very Nice Upgrade!
GoDadGo
Thanks man! I’ll keep you guys posted.
