Thanks Thanks:  48
Likes Likes:  504
Page 10 of 23 FirstFirst ... 8910111220 ... LastLast
Results 361 to 400 of 885
Thread: Kit 075 Restart
  1. #361
    You really don't have to decide until the prep is nearly done. liked the metal diecastmodelswholesale model 33 Fords to try out different colors on.
  2. #362
    Senior Member JOP33's Avatar
    Haslet, Texas
    Looks great! Can't wait to see her rollin' around the Metroplex!
  3. Thanks wrp thanked for this post
  4. #363
  6. Likes jayguy, AJT '33 liked this post
  7. #365
    Mar 2017
    Great work! Great looking car! Make it 3 inches bigger in every dimension so I can sit in it
  8. #366
    Bill-
    She is looking really sharp; I like the color, and really like the accent stripe!
    You must be pretty excited to have her almost finished. It's time to see some more cockpit videos.
    Thanks for sharing the latest updates, and I look forward to seeing her graduation post!
  9. Likes AJT '33 liked this post
  10. #367
    The guys got the glass in the front and rear window this week. They are also finalizing the electronic window hookup. The roof isn't bolted down and there is no weather stripping in it yet.
    Seq-8t.jpgSeq-8t1.jpgSeq-8t2.jpgSeq-8u.jpgSeq-8u1.jpgSeq-8u2.jpgSeq-15a2.jpgSeq-15a3.jpgSeq-15a4.jpgSeq-15a7.jpg
  11. Likes Oldguy33 liked this post
  12. #368
    Getting down to the final tweaks on the hood fitment as well. I really like the way the split side skirts came out. Here are some shots of the hood hinges.
  13. #369
    I am really pleased with the door latches. I had originally went with the pull posts. The guys at 121 convinced me the cable pulled latches and exterior hands would be the way to go. I am very pleased with the look and feel of the one that they have installed thus far. They have not done the final alignment on the doors or bolt down of the roof yet but the entire mechanism works very smoothly. Also the engine is cleaned up now and the firewall cleaned off so things are really starting to pop. Finally we are down to a few nuts and bolts left. I cannot tell what was due to contamination and what was actually left over. The guys also added a opener switch for interior lighting.
    Seq-14.jpgIMG_3120.jpgIMG_3119.jpgSeq-14a.jpgSeq-14a1.jpgSeq-14a2.jpgSeq-14a3.jpgSeq-14a4.jpgSeq-16.jpgSeq-16a.jpg
  14. #370
    Really moving fast now. Got to sit inside today and was very pleased with the overall feel from the driver's seat. Abel worked on spacers to hold the lights against the inner steel bracket and stiffen the piece of the side skirts that remain in place. He also aligned the nose cone and installed the wiper blade for effect.
    Seq-4h1.jpgSeq-4h2.jpgSeq-9t6.jpgSeq-9t5.jpgSeq-9t4.jpgSeq-9t3.jpgSeq-9t2.jpgSeq-9t1.jpgSeq-9t.jpgSeq-4h3.jpg
  15. #371
    Got another couple of pictures of the door latch pull and took some shots around the inside with the roof on.
    Seq-14a5.jpgSeq-14a6.jpgSeq-15a8.jpgSeq-15a9.jpgSeq-15a10.jpgSeq-15a11.jpgSeq-15a12.jpgSeq-15a14.jpgSeq-15a15.jpgSeq-15a16.jpg
  16. #372
    Finally got a good look at the side skirts mounted.
  17. #373
    Very interesting project at the shop. Kory has a 1928 Chevrolet Dump Truck. This truck spent its life in the Gold Fields in California. It has a 6 cylinder in it and the hydraulic dump bed works. Kory has a 2.5 4 cylinder to get it back to original, and they are missing a door. looks like an exciting project.
  18. #374
    Mar 2017
    Y'know, I bet they could turn a '35 pickup into a Sedan Delivery pretty easily... hhhrrrmmm......
  19. Thanks wrp thanked for this post
  20. #375
    Gatineau, Quebec, canada
    Tell them to put it on a white plastic and shake and clean it off onto the blanket, there may be some gold left over thats stuck in the cracks of the truck!!!!
  21. Thanks wrp thanked for this post
  22. #376
    Kory picked up an "Old Air" HVAC Under Dash Unit at MSRA Back to the Fifties. Really fits well with the console. This has heating and cooling. We most likely will not complete the installation until we do the LS swap.
    Seq-6l.jpgSeq-17.jpgSeq-17a.jpgSeq-17a1.jpgSeq-17a2.jpgSeq-17a3.jpgSeq-17a4.jpgSeq-17a6.jpgSeq-17a7.jpgSeq-17a8.jpg
  23. Likes AJT '33, HVACMAN liked this post
  24. #377
    Mar 2017
    Man! That looks PERFECT!
  25. Thanks wrp thanked for this post
  26. #378
    Unless you see it in person, words don't describe it. We took it to the upholstery shop today to have a final look at the material against the car and resolve any potential issues. We are using Leo's Upholstery in McKinney.
  27. Likes JimLev, RoadRacer, AJT '33, TDSapp liked this post
  28. #379
    Ol Skool
    upstate NY
    That really looks great! The green looks deep. Awesome job on the rod!!
  29. Thanks wrp thanked for this post
  30. #380
  31. Likes FF33rod, HVACMAN liked this post
  32. #381
    Mar 2017
    Great color choice! I am gonna need an interior soon... hhhmmmm
  33. #382
    BRG with tan - classic. Looks beautiful.
  34. Thanks wrp thanked for this post
    Likes wrp liked this post
  35. #383
  36. Likes HVACMAN liked this post
  37. #384
    Village Mills, Texas
    You should be very proud Bill. The car looks amazing!!
  38. Thanks wrp thanked for this post
  39. #385
  40. Likes HVACMAN, FF33rod, TDSapp liked this post
  41. #386
    Quote Originally Posted by wrp View Post
    I know I am putting this out of sequence but can you tell me what brand wiper arm and wiper you used? I have a marine wiper kit which has the same motor as you however the wiper arm is straight and to have this installed properly it really should have a kon or jog in it to be able to sit up high when parked. If you can tell what you used it would be appreciated. I am waiting to purchase anything until I return from the Syracuse Nationals in a couple weeks, they may have something there. TY!!
  42. #387
    Mar 2017
    Is that an Ivory-colored headliner?
  43. #388
    No sir, that is the padding under the headliner which will also be buckskin
  44. #389
    I'll have to look closer next time I go out. I think it was a vintique
  45. #390
    Mar 2017
    Excellent. I think I wll need to visit Leo soon. Maybe your paint guy too.
  46. Likes wrp liked this post
  47. #391
    You aren't that far away are you? Come on up some day and we can ride up
  48. #392
    Mar 2017
    I'm maybe 10 miles from you, easy drive. Will try to get there but I work days, and I bet Leo isn't open weekends. We will work out a long lunch or something
  49. #393
    Yes he is open to noon on Saturday. meet me for coffee Saturday morning and we can cruise by, then swing up and catch Kory. Have you home by mid afternoon.
  50. #394
    Mar 2017
    Awesome! We can plan for this , definitely! Maybe this Saturday, depending on my roofing contractor's schedule. I'll call you tomorrow. Sound good?
  51. #395
    Today they got the door panels on, started the trunk, pulled the old carpet and dynamited the aluminum floor. They also got the headliner finished and most of the console lid. Only waiting on the carpet now.
    IMG_3355.jpgIMG_3356.jpgIMG_3357.jpgIMG_3363.jpgIMG_3364.jpgIMG_3368.jpgIMG_3369.jpgIMG_3353.jpgIMG_3354.jpgIMG_3365.jpg
  52. Likes TDSapp liked this post
  53. #396
  54. Likes TDSapp, JimLev liked this post
  55. #397
    Oct 2014
    Vermilion, OH
    Bill,
    That is looking amazing! Looking forward to seeing it finished.
    CVOBill
  56. Thanks wrp thanked for this post
  57. #398
    Jul 2017
    This is going to be a show piece !! Looks great. Is that the windshield wiper motor in the hard top?
  58. Likes wrp liked this post
  59. #399
    Mar 2017
    Bill, can't make it this weekend or next. Probably can wait until August or September maybe?
  60. #400
    Yes on the windshield wiper. I have a solution already for the roadster
