Results 1 to 12 of 12
Thread: Rear brake caliper issue
    Accord NY
    I recently go carted and thought I had the sticky emergency brake issue figured out. Evidently I didn’t and fried my left rear caliper. Factory five is on back order until at least the end of June. Can anyone confirm that they are from an 87-88 T bird so I can purchase one sooner online.
    O'Fallon, MO
    ASK Ffr
    Quote Originally Posted by cfriedman67 View Post
    The original IRS was 89-97 T bird.
    89-92 (91 or 92, I forget?) T bird had a thicker rotor.
    93-97 T bird had a thinner rotor.
    Pads, calipers + rotors do not interchange between the two designs (without possibility of catastrophic failure if you mix the wrong parts together).
    I have no recollection of a 87-88 T bird caliper being commonly applied to these cars, but that doesn't mean that's not what you have...
    Mar 2013
    Fort Collins, Colorado
    Back in the old days, 87-88 Turbo T bird rotors and calipers were a common upgrade to a donor 8.8 straight axle.
    Accord NY
    Thanks all. FFR said 87-88 Tbird. They said there not suppose to tell us but he believed that’s what it is.
    Richard Oben's Avatar
    Kansas City MO
    If it is 4 lug it is 87-88 T bird, IRS is as listed above, 5 lug should be 94-04 Mustang GT or Cobra. Unless FFR has done something completely different. Richard.
    Accord NY
    Thanks for clarifying. I have a 5 lug and three link rear suspension. I will go for the 94-04 rear caliper.
    Ottawa Ontario
    I have the 87-88 T-Bird TC brakes on the rear of my MKII and if I remember correctly they use the D347 pad and have a 45mm piston diameter.
    https://www.google.com/search?q=ford...ow9k8saK99G2M:
    Hopefully this might help you confirm what you have. Scott
    Accord NY
    Thanks. I spoke to Jim Schenck today and he verified that they now use brake calipers from an 87-88 tbird turbo coupe.
    Mar 2013
    ops double post
    Mar 2013
    That really surprises me. What is the diameter of your rotors ? 87-88 Turbo Tbird rotors are only 10.25 inches, and only avail as a 4 lug unless they are re-drilled.
    Derald, they are only using the caliper not the rotor.
