Hi Guys,
As you may know I am rebuilding my 87 302. It is the factory rotating assembly and I am using all STD size bearings. After lots of research, I decided to go with Clevite CB-634P rod bearings. As I was double checking clearances tonight, I noticed that these rod bearings have a hole in them for oil. The odd thing is that the connecting rods have no holes in them for these to line up with. It seems that every mustang guy uses these as well, but I just want to make sure this wont cause a problem.
Thanks!
