Results 1 to 14 of 14
Thread: Need a little help..
    Senior Member 3yearplan's Avatar
    Dearborn Heights, MI
    I have the Russ Thompson gas pedal and the factory throttle cable from the 2004 Mach1. I don't like the sloppy fit of the cable at the gas pedal. I've been searching for a Lokar cable but I am not really sure which one to go with. If anyone could point me in a better direction I would greatly appreciate it.
    Mark IV 7923 arrived 11-14-12
    DOHC 4.6L, Tremec 3650, 3 Link 8.8 w/3.73
    cv2065's Avatar
    Dec 2017
    Here’s the one I bought. Not installed yet.
    https://www.amazon.com/gp/aw/d/B000C...op_mb_pd_title
    Senior Member brewha's Avatar
    Aug 2013
    Somers, Ct
    You should consider building or buying a throttle linkage and forget the cable. There are enough threads you can search on the forums to get a parts list or just look into a Fortes kit. It would be one less thing to worry about breaking when out on the road.
    Jacob's Avatar
    Rogers, AR
    I built throttle linkage with parts from McMaster Carr, it’s easy...in my opinion you’re asking a lot of a cable to make 2 180’s?
    MK IV complete Kit - 1st time builder started Sept 2016
    Levy 306
    T5
    2015 Mustang IRS
    Power steering - Levy setup, Breeze roll bars, Thompson trunk box
    fuel injection, powder coating, sway bars, heater, wipers, 17 in wheels
    Senior Member jrcuz's Avatar
    Stafford Virginia
    Look at edwardb's build thread for I beleive his second roadster. He has a detailed parts list. I used it to assemble my mechanical throttle with the Russ Thompson gas pedal. Everything looks and works great
    cv2065's Avatar
    Dec 2017
    Quote Originally Posted by jrcuz View Post
    Thanks for this. I must have missed that. Do you have a link to Paul’s thread? I looked but couldn’t find it. Thanks!
    This is the referenced post. Was before Mike had his available and is slightly cheaper if you like shopping and a little fabrication. I highly recommend the mechanical linkage over a cable. Wouldn't be particularly easy to add to a completed car, so now's the time to do it.
    https://thefactoryfiveforum.com/show...l=1#post137426
    Thanks for all the great replies. This is somewhat of an ignorant question, "does the throttle linkage only work in a north/south configuration?" My throttle pull is from the driver side to the passenger side, aka, east-west. Not to second guess anyone, or their preference, but wouldn't a vehicle with relatively low miles driven per year with a throttle cable last quite some time? I know the odds of durability are in favor of a car with linkage, but what are the odds of a failure with a cable ?
    Thanks again, Mike
    Quote Originally Posted by 3yearplan View Post
    ...Not to second guess anyone, or their preference, but wouldn't a vehicle with relatively low miles driven per year with a throttle cable last quite some time? I know the odds of durability are in favor of a car with linkage, but what are the odds of a failure with a cable ?
    Well, that 2004 Mustang you pulled the cable from and millions of others just like it usually live their entire life with the same cable that they left the factory with.
  10. Likes 3yearplan liked this post
  11. #10
    I think you are correct as long as you use a Ford cable and it doesn't have any more bends than it did in the Mustang. Most comparisons are between a lokar and a linkage. My experience is that the linkage is so much better I would never again consider a cable.
  12. #11
    Stafford Virginia
    Also I wasn't having much success making my own threaded rod so I got these from Mcmaster-Carr 1 ea 6516K118 connecting rod 9" overall length and 1 ea 6516K14 connecting rod 12" overall length. Both are 1/4"-28 thread. I did have to shorten them slightly but was not a problem.
    JR
  13. Thanks sbhunter thanked for this post
  14. #12
    cv2065's Avatar
    Dec 2017
    Man, now I’m going to have to get the Forte linkage. You guys are killing me!
  15. #13
    Aug 2017
    Southern WV
    Just think of it as the gift that keeps on giving there is always something you want or need to do
    Rick
  16. #14
    IMO reliability isn't really a valid reason to go linkage, but looks and most importantly feel are two very good reasons for the mod. Linkage will remove any of the slop that the OP stated as a concern. For me, I made an adjustable linkage that allows full throttle at the pedal to vary from 20% to 100% at the throttle body. Kind of a low tech valet mode.
