![Very Cool Parts](https://thefactoryfiveforum.com/attachment.php?attachmentid=40527&d=1428867450)
02 wrx to LGT trans axel difference?
Good evening,
My 210k 02 donor transmission is on it's last leg. I have 09 (canbus not an issue) LGT trans available. I know I need the male axle stubs o. The trans mission side, would I need new axles from FFR as well or can I remove the female stubs and put male stubs on the ones I currently have for the 02 trans.
Respectfully,
You should be able to put the male stubs in the LGT transmission.
You would need to change the diff side seals as well though. The male and female side diff seals are different sizes.
Other than that it should be fine.
ssssly
That's easier said then done lol.
After re reading my post and noticing my poor description of the issue I am going to take another whack at it. So my 02 trans uses female CV axles as the diff has the male stubs. The 09 uses male CV axles as the diff does not have the stubs. I have complete axles for the 02 which have the female end on the trans side of the axel. Can I dissasemble the axles trans side and put male stubs on it or are the splines/length different and I would need to purchase the axles from FFR.
The other less desirable option would be to swap diffs from 02 to 09 which beyond splitting the case would also require chnging the ring gear or swaping pinions setting back lash and replacing bearings.
The male and female CV ends are not swapable. The axles have different spline counts. At least the set I tried to do this with a couple weeks ago were.
The male stubs that come out of the center diff are removable. They are not part of the the center diff. They are just held in with c-clips. So no need to swap diffs. Just remove the stubs and change the seals.
This does require opening the transmission. But as long as you mark the side covers well and count the number of turns to get them out, you don't have to redo the backlash if all you do is remove the stubs and change seals.
Got it pull the diff pin remove spider gears and c clips on stubs put them in the LGT trans diff. Thank you.
![Stewart Transport](https://thefactoryfiveforum.com/attachment.php?attachmentid=40533&d=1428868052)
