From manual: The color coding for the lights is: White (Ground), Black (Running light), Red (Stop/Turn signal). This is in the back of the book for some reason.
Also "Cut the yellow and white rear turn signal light wires off the turn signal connectors that are for the dash turn signal switch so that the turn signal lights do not back feed and light the front turn signals when the brakes are pressed
Good luck,
tommy23t
